29488 Discussions
Can't get install to work on RH EL 4 installation...
Richard_M_1
When I try, I get an error from osdetect.sh complaining about not being able to find libgcc_s.so.1 which I can find in /usr/lib/gcc/x86_65-redhat-linux/3.4.3 but not anywhere else. Is this supposed to be generally installed. If not, where can I get it from? This is a pretty generic RHEL 4 installation.
Best,
Dick Munroe
TimP
The release notes give advice about this. In short, for x86-64, you must install all the gcc/g++ development system options of EL4, including 64-bit g++, 32-bit "legacy" g++, and "compatibility" libraries. If the compatibility library option isn't present, you must install the libcompat .rpm.
