29389 Discussions
Can the idb intel debugger find maxval, sum etc of variables during debugging?
Wee_Beng_T_
I am now using the gui intel debugger. May I know if it has the ability to give me the maxval, sum etc of variables during interactive debugging.
I need to check that the output from my new and old are similar. It's very troublesome to keep on using print. Else is there any debugger that can accomplish the task, either in linux or also in windows?
Thanks!
Ron_Green
You should be able to use most intrinsic functions in IDB expressions, including print expressions. However, there are some functions that may not work: functions that require special data types or alignment requirements.
Do you have a specific example where this is not working?
ron
Wee_Beng_T_
Hi Ronald,
Supposed I have this simple code:
program array
implicit none
real :: a(10)
a=1.
print *, sum(a)
end program array
I can use the print command to print out the sum of a. However I wonder if I can use intel idb to show me the ans (sum(a)=10) as well?
I tried to input sum(a) in the evaluation and vector evaluation windows but they both can't work.
Thanks again!
