Cannot compile
weichao
I run /opt/intel/compiler70/ia32/bin/ifcvars.sh before I use ifc, but it still
cannot find the path:
-bash: ifc: command not found
I forget how to set the environment parameters to avoid to run ifcvars.sh every time after a command window is opened. Anyone could help me? Thanks.
Dennis
Did you use the source command to run the script?
