Cannot find ifort XE 15 in Xcode6.2
Johnson_Y_
Hello, I've installed ifort 15 (and Xcode6.2 with command line tool) and have followed the instructions on https://software.intel.com/en-us/node/524635. to build a fortran file. When I'm suggested to add build rule and to select Intel® Fortran Compiler XE 15.0, I cannot find it under Using. I've tried to reinstall  Intel® Fortran Compiler XE 15.0 and restart Xcode but it still doesn't work.
Xcode 6.2 is not yet supported. I haven't heard specifically if it works or not, but if you installed Xcode after Fortran you need to uninstall and reinstall Fortran any time you change Xcode versions.
