29376 Discussions
Cannot invert a matrix with IMSL routine LINDS
Pratap__Sangeeta
I am trying to use a standard IMSL routine LINDS to invert a positive definite matrix,.
I installed the IMSL library based on these instructions.
https://software.intel.com/en-us/articles/installing-and-using-the-imsl-libraries
Then I included the lines
INCLUDE 'link_fnl_shared.h'
use linds_int
in my program, before setting up the matrix to be inverted
The program compiles without error, but when I debug it it, it exits without inverting the matrix. It  does not trigger a break  point, but it just stops.
Any help will be greatly appreciated. Thank you very much
mecej4
I have this comment regarding the first part of the program code in #20.
You compute X = ATA for a matrix A of size 338 X 3 and then find the inverse of X. For the particular matrix that you chose, i.e., aij = floor(i/j), the condition number of A is  about 930, and the condition number of X is the square of that, i.e., about 9 X 105. If you calculate X in single precision, that means that only one or two significant digits may be correct.
Two further points to note: in general, it is bad to form the normal matrix X and then work with it. If your ultimate objective is to solve overdetermined linear equations A.x = b, for example, rather than forming X, use the well-known QR decomposition of A. Likewise, it is bad practice to form the inverse matrix explictly if your objective is to solve linear equations. When I say "bad", I mean (i) inefficient and (ii) inaccurate. Any book on numerical analysis and Wikipedia articles can provide you with details on why the "bad" happens.
JohnNichols
Valued Contributor III
Let us stop this string of notes - it is gettting quite long, there are innumerable books, and the solution is well known.
