29627 Discussions
Cannot see allocatable array elements within subroutine in debugger
Terry_Wong
I am using Visual Studio 2012 (version 11.060315.01 Update 2), and Intel Fortran w_fcompxe_2013_sp1.1.139.
I am having difficulty seeing member variables of a user defined type in the debugger.
First, I define a type within a module.
module module1_mod
  public
  type testtype
    integer, allocatable, dimension(:) :: ipt1
    real, allocatable, dimension(:) :: rpt1
  end type testtype
end module module1_mod
Note that this problem will fail with the members of the type being pointers instead of allocatable arrays also.
I have a program which passes a variable of type testtype to the subroutine.
    program Console1
    use module1_mod
    implicit none
    ! Variables
    type(testtype) :: amod
    real :: arr(15)
    interface asub
      subroutine asub(amod, arr)
      use module1_mod
     type(testtype), target :: amod
     real :: arr(:)
      end subroutine asub
    end interface asub
      allocate(amod%ipt1(10))
      amod%ipt1 = 1
      allocate(amod%rpt1(10))
      amod%rpt1 = 10.
      arr = 15.
      call asub(amod, arr)
    end program Console1
I have even added an explicit interface so there is no ambiguity.
I call the subroutine:
    use module1_mod
    real :: arr(:)
    type(testtype), pointer :: pt
    pt => amod
    amod%ipt1 = amod%ipt1 + 2
    return
end subroutine asub
In the debugger, I cannot see the elements of amod.  amod%ipt1 shows {...} but cannot be expanded; amod%rpt1 shows undefined address.
However, I can see the elements of the local pointer pt fine.
Georg_Z_Intel
we're aware about the problem you described. For Intel(R) Composer XE 2013 SP1 Update 2 (released beginning February) it should be fixed. Please let us know whether it also works for you.
Georg Zitzlsberger
IanH
This may not be relevant to your particular problem (I don't have VS2012 to test), but something to try - after the line in the watch window for the array or array component, that won't expand add a watch for a simple scalar.  Often that seems to encourage the watch window to start behaving itself.
The other thing to try is to run the application a second time (the debugger appears to have more issues when debugging immediately after a build than it does debugging a second or subsequent run).
Also, using the immediate watch tip thing (move the mouse pointer over the name of the variable of interest, expand things) before using the watch window sometimes encourages the watch window to work.
Rather bizarre, but [occasionally, with poor reproducibility] true!
Terry_Wong
Thanks for your suggestions.
I tried them but none of them were effective.
Georg_Z_Intel
Georg Zitzlsberger
