29487 Discussions
Cannot use IMSL library - produces error
nairsk
I just purchased the Intel Visual Fortran Compiler Professional Edition with IMSL Math Library. I used an example code in the IMSL library and tried to compile it. The code is provided below.
use lin_sol_gen_int
use rand_gen_int
use error_option_packet
implicit none
! This is Example 1 for LIN_SOL_GEN.
integer, parameter :: n=32
real(kind(1e0)), parameter :: one=1e0
real(kind(1e0)) err
real(kind(1e0)) A(n,n), b(n,n), x(n,n), res(n,n), y(n**2)
! Generate a random matrix.
call rand_gen(y)
A = reshape(y,(/n,n/))
! Generate random right-hand sides.
call rand_gen(y)
b = reshape(y,(/n,n/))
! Compute the solution matrix of Ax=b.
call lin_sol_gen(A, b, x)
! Check the results for small residuals.
res = b - matmul(A,x)
err = maxval(abs(res))/sum(abs(A)+abs(b))
if (err <= sqrt(epsilon(one))) then
write (*,*) 'Example 1 for LIN_SOL_GEN is correct.'
end if
end
I used the following command to run this code on the C:\\ Prompt:
ifort Example_1.f90
It produced the following errors:
Error LNK2019: unresolved external symbol _S_RAND_GEN referenced in function _MAIN_
Error LNK2019: unresolved external symbol _S_LIN_SOL_GEN referenced in function _MAIN_
Could you help me resolve this and get going? Thanks.
You need to tell the compiler to link to the IMSL libraries, and to which set of libraries. This is described in the on-disk documentation under Using Libraries > Using IMSL.
The easiest way is to add the following lines to your source, before the USE statements:
[fortran]include 'link_fnl_static.h'
!dec$ objcomment lib:'libiomp5md.lib'[/fortran]
For additional information, see Installing and Configuring the IMSL Libraries.
