29627 Discussions
Cannot use ifort command after update
Wai_Kiat_T_
I updated my Intel Parallel Studio XE 2016 to Update 2 and I cannot use ifort command in Intel Compiler 16.0 Update 2 Intel(R) 64 Visual Studio 2015. The error message was "'ifort' is not recognized as an internal or external command, operable program or batch file.".
However the ifort command is still working fine in Intel Compiler 16.0 Update 1 Intel(R) 64 Visual Studio 2015.
You indeed have neither Fortran nor C++ there. At this point I suggest uninstaling Update 2 and reinstalling. Pay very careful attention to any warning messages it gives you. At the Summary page where it tells you what will be installed, make sure it says Fortran for 32-bit and 64-bit will be installed.
Lorri_M_Intel
I saw your screen captures on stackoverflow.
Is there a chance that when you did the upgrade, that you installed the C-only kit?   Will the "icl" verb work in your command prompts?
Were there any messages when you did the install, including warnings that seemed benign?
When you bring up the Update 2 command prompt, what do you see if you issue the "dir" command?
             --Lorri
Wai_Kiat_T_
Hi Lorri, thank you for your reply.
  1. I did the upgrade via Intel Software Manager, so I guess I installed C/C++ and Fortran. The verb 'icl' was not working in my command prompt too.
  2. During the installation, everything was going smoothly, I did not recall seeing any warnings or errors.
  3. If I issue the 'dir' command, I see the directories in C:\Program Files (x86)\IntelSWTools
Regards. Wai Kiat.
Please show us the output of the command prompt window after you open it (from the shortcut that is installed in the Start menu.)  Please also show the output of:
dir compilers_and_libraries\windows\bin
Wai_Kiat_T_
Hi Steve. Attached figures are the output of the command prompt window (top) and the output of 'dir compilers_and_libraries\windows\bin' (bottom). Please let me know if there is anything wrong. Thank you so much.
Wai_Kiat_T_
Hi, Steve. Thank you for your reply. My desktop is now running a simulation which will take some times. I will try your suggested method once my PC is available. Cheers, Wai Kiat.
Wai_Kiat_T_
Hi, Steve. I did a clean installation by removing Intel Parallel Studio XE 2016 Update 1 & Update 2, then I reinstalled Intel Parallel Studio XE 2016 Update 1 and updated to Update 3. Now I have two versions of command prompts: Update 1 and Update 3 for both x86 and x64, did I update it correctly?
The following is the output of "dir compilers_and_libraries\windows\bin" from Intel Compiler 16.0 Update 3 Intel(R) 64 Visual Studio 2015. I also can invoke the command "ifort" and "icl /c"in this new command prompt.
C:\Program Files (x86)\IntelSWTools>dir compilers_and_libraries\windows\bin
 Volume in drive C has no label.
 Volume Serial Number is F23C-55AB
 Directory of C:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\bin
05/06/2016  07:54 PM    <DIR>          .
05/06/2016  07:54 PM    <DIR>          ..
04/16/2016  07:49 AM             4,568 compilervars.bat
04/20/2016  03:35 PM            13,368 compilervars_arch.bat
05/06/2016  07:54 PM    <DIR>          ia32
05/06/2016  07:54 PM    <DIR>          ia32_gfx
04/16/2016  07:49 AM             4,568 iclvars.bat
04/16/2016  07:49 AM             4,568 ifortvars.bat
05/06/2016  07:54 PM    <DIR>          intel64
05/06/2016  07:54 PM    <DIR>          intel64_gfx
05/06/2016  07:54 PM    <DIR>          intel64_ia32
05/06/2016  07:54 PM    <DIR>          intel64_mic
04/16/2016  07:49 AM             1,613 ipsxe-comp-vars.bat
04/16/2016  07:46 AM            67,958 loopprofileviewer.jar
04/16/2016  07:49 AM             1,617 vsshell2010vars_arch.bat
04/16/2016  07:49 AM             2,312 vsshell2013vars_arch.bat
               8 File(s)        100,572 bytes
               8 Dir(s)  55,277,006,848 bytes free
It does sound as if it is working for you now and yes, it's normal to have both shortcuts showing.
