Cannot watch array values in IFX
Jon_D
New Contributor II
I am not able to see the values of the three automatic arrays in the DoSomething subroutine of the code below in a debug session using IFX. The watch window shows them as arrays with dimension 15 but their values show as "Undefined address". I am using oneAPI_2024.2.1.1083 with VS 2022 Community Edition.
Is there a way I can properly watch these arrays or is this a Fortran-VS integration issue?
Thanks!
module aModule
    implicit none
contains
    subroutine DoSomething(ne,ilutype)
        integer,intent(in) :: ne,ilutype
        real(8),dimension(ne) :: relemvalues,relemvalues_short,relemvalues_surplus
        select case (ilutype)
            case (1)
                relemvalues = 5.0
            case (2)
                relemvalues = 8.0
            case default
                relemvalues = 1.0
        end select
        relemvalues_short   = 0.0
        relemvalues_surplus = 0.0
    end subroutine DoSomething
end module aModule
program main
    use aModule
    implicit none
    integer :: ne,ilutype
    ne      = 15
    ilutype = 1
    call DoSomething(ne,ilutype)
end program main
