- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Apparently with I use LEN_TRIM to get the length of an input line,
it stops when I come to a blank character.
I thought LEN_TRIM was supposed to give me the length of the whole line.
Is there some other way to get that?
For example:
100 format(A)
open(5,file="text1.txt")
character*80 line
integer ll
read ( *,100)line
ll=len_trim(line)
if text1.txt has AA BBB CCCC DDDDD in it, I get ll=2.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
5 is a bit of an unfortunate choice of unit number. For ifort and many other compilers it corresponds to the logical unit used for standard output (the same as used by a print statement or write (*,...)).
(Though it is unfortunate that ifort continues to use those numbers for that role with /standard-semantics.)
If I modify your program to write its own little test file, I don't see the behaviour you describe.
[fortran] program test19
implicit none
character*10 line
integer ll
open(10,file="2013-10-30 readline.txt", status='replace', action='write')
write(10,"(A)") 'AA BBB CCCC DDDDD'
close(10)
open(10,file="2013-10-30 readline.txt")
do
read(10,100,end=90)line
100 format(A)
ll=len_trim(line)
print *,"ll=",ll
enddo
90 print *,"EOF encountered"
read "()"
end program test19
[/fortran]
I get ll=10, which is the length of the character variable.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Well of course the FORTARAN library is compatible
with files that IT HAS WRITTEN, but I was trying to point out the problem with files
of type TXT. So is there some other way to read those?
That other more elaborate example gives wrong values for the line lengths.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
If you want to read an entire record (i.e, line) into a character type variable, and the line is likely to contain blanks, do not use list-directed input. The Fortran Ref. Man. says under the rules for list-directed input: "A nondelimited character string is terminated by the first blank, comma, slash, or end-of-record encountered".
Secondly, declare the character variable to be of sufficient size to hold the largest input line in the data file being read.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I initially made the same mistake - seeing the * in the read and immediately thinking this was simply due to list directed format. But the formats in the code examples are explicit "(A)".
Bill - could you attach the problematic text file?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I just used the README.txt from creating an ifort console project in visual studio and I see:
[plain] ll= 10
ll= 10
ll= 10
ll= 0
ll= 9
ll= 10
ll= 0
ll= 9
ll= 9
ll= 0
ll= 10
ll= 10
ll= 10
ll= 9
ll= 10
ll= 10
ll= 0
ll= 10
ll= 10
ll= 10
ll= 0
ll= 10
ll= 10
ll= 0
ll= 10
EOF encountered[/plain]
which is what I'd expect.
All but the same program as what you attached, (same as what I attached above, but with the file writing bit chopped out) but with the unit number changed to 10. Compiled with /warn:all /check:all /standard-semantics.
Check that what you are running is what you think it is, that what is actually the input file is what you think it is, and make sure your program doesn't use READ (*,*) list directed formatting, as mecej4 (why the "4"?) suggests.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
A likely reason for the read problem is the file is not a DOS format file. This is about the only source of a read error you can get with an A format.
In a DOS file, each line is terminated with <CR><LF>.
I think for a unix file, each line is terminated with a <LF> only and I have recently scanned a file that uses <CR> only.
Opening the file as unformatted, fixed length records with length of 1 byte should allow you to read each byte and determine the contents.
Wordpad is fairly robust for looking at small "text" files.
John
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Bill,
If you change the print statement to also include printing the variable "line" (without the trim), then you would see exactly what had been read in. You could also try to look at the readme file in an editor which is able to display the contents in hexadecimal to see what comes after the first two characters, something is causing the read to stop after them. The test19 code as written should work but ...
Les
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
What it seems to be returning is the number of characters until the first blank is encountered. Now if the file is WRITTEN with a Fortran Write statement, then blanks don't trigger that, as we might expect. So the problem isn't reading the file in, as it is using the LEN_TRIM statement to get the
length actually read in.
I will experiment with this some more. Maybe there is a special way to open the file, as has been suggested.
Or perhaps the Fortran libray was not suited to read in files of this type?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
In your example test19.f90 you have
character*10 line
so you will never get a length LL greater than 10. The example Ian posted seems to give correct answers. You need to declare the buffer larger than the max line length.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Bill,
You should attach the file so we can look at the contents.
Could len_trim be responding to a null character value that is being read in?
John
ps: I tried the attached example, to include null, CR or LF characters in the string, but always returned the active string length, ignoring trailing blanks. Even extending the active string with a null worked. Attach the file so we can see the problem.
Should you check your disk for errors !!
pps: A have attached a program that reads any file, opening as binary, which looks for control characters. It should read any file up to the "end_of_file" and can report any control characters and also the end of line control format. Give it a go and report what it finds. If the problem is the file content then this should identify it. Failing that as the source of the problem, you must have a coding problem that you have not identified.
For reading text files, "format (A)" is usually very robust !!
