Catastrophic ICE when compiling with -standard-semantics
Lester
I have come across an ICE when compiling with -standard-semantics.  The compiler used is
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.0.1.117 Build 20121010
Copyright (C) 1985-2012 Intel Corporation.  All rights reserved.
The machine is
Linux 3.6.11-1.fc17.x86_64 #1 SMP Mon Dec 17 22:16:35 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
Unfortunately, the program is pretty complicated. I am uploading a bzip compressed tar file with enough of it to demonstrate the problem, along with a makefile.  If -assume norealloc_lhs is added to the options, the ICE goes away.
Steven_L_Intel1
Thanks - I can reproduce the error and will see if I can reduce the test case, then I will escalate to development. I will follow up here with any news.
I suggest that you modify your Intel Developer Zone profile to choose a "Display Name" that is not your email address.
Steven_L_Intel1
This problem is fixed in Update 2, which will be released later this month.  A workaround is to replace line 167 in moredt_I.f90, which reads:
iropt= max(iropt, iropt(icell))
with:
iropt = max(iropt(icell), iropt)
This will give the same result and avoid the compiler error.  Please let me know if this helps.
Lester
Thanks for the patch.  Since the reallocate was the major reason for turning on standard semantics, its good to not have to disable it for this routine.
