29647 Discussions
Catastrophic error with Intel Compiler 17
luiceur
Version: intel-compilers-17/17.0.2.174
File: connolly.f from the Tinker application https://dasher.wustl.edu/tinker/
mecej4
No problems on Windows:
S:\lang>ifort /c /Od sizes.f  math.f inform.f atoms.f sizes.f faces.f iounit.f connolly.f
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on IA-32, Version 17.0.2.187 Build 20170213
Copyright (C) 1985-2017 Intel Corporation.  All rights reserved.
Which platform are you running on, and are you generating for X86 or X64?
[P.S.] I edited the command line after reading Lorri's observation below.
luiceur
This is for x86_64.
$cat /proc/version
Linux version 3.10.0-327.36.3.el7.x86_64 ([email protected]) (gcc version 4.8.5 20150623 (Red Hat 4.8.5-4) (GCC) ) #1 SMP Mon Oct 24 16:09:20 UTC 2016
luiceur
I should add, it works for Intel 16.
Steve_Lionel
Intel would want you to file a support ticket for this.
luiceur
Thanks Steve, I will do it.
Lorri_M_Intel
And when you do submit the problem report, please include the exact command line you used.   I just experimented using the simple command line that mecej4 used, and was able to compile connolly.f.  (Although, I admit, I compiled sizes.f first then the rest of the files)
           thanks -
                                  --Lorri
