29594 Discussions
Catastrophic internal compiler error with (apparently?) valid parameterised derived type code
Warrick
I've come across an internal compiler error with ifort 19.0.1.144 with some code that defines assignment for a parameterised derived type. I've stripped the project code down to this minimal example:
module types
   implicit none
   type :: test_type(n)
      integer, len :: n ! Length of array of independent variables
      integer :: t(n)
   end type test_type
   interface assignment(=)
      module procedure assign_from_self
   end interface assignment(=)
contains
   subroutine assign_from_self(this, other)
      type(test_type(n=*)), intent(out) :: this
      type(test_type(n=this%n)), intent(in) :: other
      this%t = other%t
   end subroutine assign_from_self
end module types
program ifort_bug
   use types
   implicit none
   call test_subroutine(3)
contains
   subroutine test_subroutine(n)
      integer, intent(in) :: n
      type(test_type(n=n)) :: x
   end subroutine test_subroutine
end program ifort_bug
If I try to compile this (saved as ifort_bug.f90), I get the following error:
$ ifort ifort_bug.f90 -o ifort_bug.x
ifort_bug.f90(1): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it oc
curred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for ifort_bug.f90 (code 1)
I know parameterised derived types have limited support and there are many known issues (recentish examples here and here) . In fact, the offending block in our program is probably going to be removed because it's causing problems in other compilers too. But I figure it's still worth raising in the hope that it'll be fixed someday!
I use ifort via an institutional license and I'm not sure how to access the Online Support Centre.
FortranFan
@Warrick ,
Thank you for your post, yep defined assignment and defined operators are among the other aspects with parameterized derived types that cause the Intel Fortran compiler to trip over, an internal compiler error (ICE) being an especially pernicious manifestation of the underlying issues with the implementation (or faults thereof) of this feature in the compiler.
I hope someone from Intel team will take note of your post and file a compiler bug report on your behalf.
Johannes_Rieke
New Contributor III
Hi, I confirm the behavior for 19.1.2.254 (PSXE2020u2).
However, if you change:
use types
to
use types, only : test_type, assign_from_self
it compiles fine.
I added a modified working version. Maybe that's a workaround?
Johannes_Rieke
New Contributor III
Sorry, with the use only, the assignment is not needed and the ICE therefor is gone. My fault.
Ron_Green
I filed a bug, ID is CMPLRIL0-23475 for the original code and ICE
This affects 19.0.x 19.1.x and 2021.1-beta
We have been fixing a number of things in PDTs so this fits in with that effort. Thank you for bringing this to the Forum
Ron
Warrick
Thanks! I presume there's nothing further to do on my side.
Ron_Green
@Warrick this issue is fixed in the 2023.2.0 oneAPI packages, ifort 2021.10 and ifx 2023.2.0
