29649 Discussions
Changing CoArray Working Directories
ScottBoyce
Is it possible to have different coarrays work on different working directories?
For example I have a variable WorkingDIR
  • that holds a different windows location on each image (say "c:\Image1\" and "c:\Image2\" and so forth). How do I set each coarrray to operate in their own specific working directory? The following SYSTEM command does not seem to work
  • [fortran]
    IERR=SYSTEM('cd '//TRIM(WorkingDIR))
    [/fortran]
    I am assuming because it opens a new cmd window and then imediately closes it while keeping the main program running in the original location.
    ScottBoyce
    I just found the command CHANGEDIRQQ that seems to be working. Are there any standard FORTRAN commands that can do the same?
    IanH
    The Fortran language doesn't know about the concept of directories.
    I tend to just prefix all filenames in OPEN statements and the like with your equivalent of WorkingDir.
    jimdempseyatthecove
    Scott,
    An "Image" is run as a seperate process. Each process can have its own "current directory" and/or "current drive" and/or "PATH", ... "environment variables", ... resources.
    Jim Dempsey
    ScottBoyce
    Thank so much, thats great to know. How would you set an environmental variable for different images?
    My program is working great by having each image use CHANGEDIRQQ to operate in different folders.
    There is no support for changing environment variables for specific images. I would say it is a bad idea to do this and would suggest putting the path you want as DEFAULTFILE in an OPEN statement. SYSTEM doesn't work because all that does is change the directory of the subprocess that SYSTEM creates - and then it goes away.
