29650 Discussions
Check argument values at compile-time?
franzw82
Hi there,
is it possible to write a subroutine / function which 1) only accepts a discrete number of integer values as inputs and 2) allows to check this at compile time?
[fortran]module test
integer, parameter :: possible_value1 = 1, possible_value2 = 2
contains
subroutine nice_routine (number)
   integer, intent(in) :: number
end subroutine nice_routine
end module test[/fortran]
In this example any integer number can be passed to the subroutine. Would it be possible to change it in such a way that only "possible_value1" and "possible_value2" are accepted and a compile-time error is issued for other values?
Thanks, Franz
You can't do it quite that simply, but you could do it like this:
[fortran]
module my_values_mod
implicit none
private
public :: possible_value1, possible_value2, nice_routine
type my_value_type
private
integer val
end type my_value_type
type(my_value_type), parameter :: possible_value1 = my_value_type(1)
type(my_value_type), parameter :: possible_value2 = my_value_type(2)
contains
type(my_value_type), intent(in) :: number
print *, number%val
end module my_values_mod
program test
use my_values_mod
call nice_routine(possible_value1)
call nice_routine(possible_value2)
end
[/fortran]
The caller of nice_routine can't construct or pass any values other than the ones you defined in the module, since the type is private. (Making the components private too is unnecessary here, but it doesn't hurt.
jimdempseyatthecove
Steve,
Are private types within a module tagged with a signature of the module name?
IOW is (private) type(my_value_type) inside my_values_mod different from type(my_value_type) inside your_values_mod?
As well as different from type(my_value_type) declared in the scope of a program, subroutine, function?
Jim Dempsey
Jim,
As long as the type is private, its name does not "leak out" of my_values_mod", so it does not interfere with the same name used for any other identifier in another module (or even in the main program.) If the type was not private, then it would be an error to use both my_values_mod and your_values_mod when the name my_values_type was referenced.
