Checkboxes in Listview control
rjar
I want some information on how to check and uncheck in a listview control. I don't have an image list in my listview control just the extended style for displaying check boxes.But I am unable to process check box messages.
I am not sure what the specific values of elements of the lv_item struct should be(the lvitem%state,lvitem%statemask,etc).
I am able to check the checkboxes if I do the following:
lvi%state=8192
lvI%stateMask = LVIS_STATEIMAGEMASK
ret = SendMessage (hwndlist, LVM_SETITEMSTATE,
sz_list,LOC(lvi))
and uncheck them by setting lvi%state to 0.
But this is different from what has been given in help for the state parameter.
In Help they have asked us to use a value for the state member to be the one-based index of the state image shifted left 12 bits. The stateimage index value is 2 in my case because that index when shifted by 12 bits results in 8192(the value I've used to check the check boxes).But how will zero cause them to be unchecked again?
Archana.
