29542 ディスカッション
Cmake build failure with LTO on Linux
Mark_Lewy
高評価コントリビューター I
3,319件の閲覧回数
We have a Cmake build script set up to build our program on Linux.  This works fine with IFORT, but I'm having an issue with IFX and LTO (link time optimisation).  With IFORT we were using IPO (inter-procedural optimisation).
We have 4 shared libraries that are compiled with -ipo with IFORT); these now use -flto with IFX.
We also have a static library that is compiled with -ip with IFORT; when I change this to use -ftlo, I get a link error:
ld: error: LLVM gold plugin: Never resolved value found in function (Producer: 'Intel.oneAPI.DPCPP.Compiler_2023.1.0' Reader: 'Intel.oneAPI.DPCPP.Compiler_2023.1.0')
This links successfully if I omit -flto for the static library.
Before I try cutting this down, has anyone had similar issues or a solution?
OneAPI 2023.1
Ubuntu 20.04 LTS
Cmake 3.26.4
0 件の賞賛
1 解決策
Mark_Lewy
高評価コントリビューター I
3,283件の閲覧回数
I found out what was happening, because I had similar link issues with LTO (/Qipo) on Windows with IFX.
I had to disable optimisation on one file in the static library because it ICEd otherwise (this has been reported (05854745) and should be fixed in OneAPI 2023.2).
Disabling optimisation also disables LTO.
It also appears that all files in a project need to be compiled with LTO enabled for it to link correctly.
Luckily, the code in the offending file is not used yet, so I could just comment it out and use the default project optimisation option.
One other point was that I was also having link issues with a C++ DLL using IFX/LTO dependent libraries on Windows.  In this case, the problem was the C++ project was using the Microsoft VS 2019 Platform Toolset (so not using the LLVM linker).  Switching to Intel C++ resolved this.
元の投稿で解決策を見る
1 返信
Mark_Lewy
高評価コントリビューター I
3,284件の閲覧回数
返信
