Coarray Debug Error
Lei-D
Hallo,
I could not debug the code with coarray.
I describe my problem in "Debugging a Fortran Coarray Error.docx".
My used environment in "MySystem.docx".
The code is "weather_parallel.zip".
Thanks for any tips!
Lei
Steve_Lionel
Note - the article Lei has attached and annotated is How to Gain Control of Debugging a Fortran Coarray Application, which I wrote many years ago. I don't recognize the MPI error messages shown.
Lei-D
Hallo, Steve,
Thanks for your note!
Could you repeat my error ? or if you have some examples which could debug coarray?
Regard,
Lei
Steve_Lionel
You didn't follow the instructions exactly, as you inserted:
use Coarray_Debugging, only: Enable_Coarray_Debugging
when the article said to use:
I'm not sure this mattered, though.
I did run into some issues when my system had more images than the code wanted, but when I restricted it to 8 images, I was able to debug image 2, stepping through the program code, and the program output:
 Maximum wind speed measured is    11.20000     at station 42003
 Highest mean wind speed is    10.52308     at station 42003
 Lowest mean wind speed is    3.376923     at station 42035
Lei-D
Hallo, Steve,
According your instruction, I have repeated the debug process and get the same error.
I find even I do delete the module "Coarray_Debugging", the error still happens, and similiar information as before.
(Refer to the attached files)
This means the error for me related to "Distributed Memory (/Qcoarray:distributed)", in assemblage between OneAPI and MPI.
Lei
Steve_Lionel
Oh... Distributed. No, that won't work. Use Shared for debugging.
Lei-D
Hallo, Steve,
in the file "MySystem.docx" attached before, I have already mentioned: "With For Shared Memory (/Qcoarray:shared), the processes will be finished quickly without stopping. "
For me not possible to debug using Shared Memory.
regards,
Lei
Steve_Lionel
It worked for me when I followed the instructions in the article.
Lei-D
More test results:
excute the code in MS Visual Studio 2022,
With or without "call Enable_Coarray_Debugging":
the processes will be quickly ended without stop at any debug points,
and no output from code are found.
excute the code using cmd,
with "call Enable_Coarray_Debugging":
D:\_Jiang\Temp\Intel_Error8\weather_parallel - Kopie\Console2\x64\Debug>Console2.exe
Image 2: Console2.exe(7624)
Image 1: Console2.exe(13664)
Comment: The process waits here without end
Comment: The process finishes normally
With For Single Image (/Qcoarray:single),
excute the code in MS Visual Studio 2022:
when without "call Enable_Coarray_Debugging",
the processes will be finished with good debug,  and it finishes normally.
when with "call Enable_Coarray_Debugging",
the processes will work only to the debug point "call SLEEPQQ(500)",
after that, the code seems always call SLEEPQQ(500).
