Coarray vs optimization
Lei-D
Hallo,
I am tring to add coarray into my old code.
IF (this_image() == 1) THEN
     ! Run old bigger code here
     ! Try to change some computing into coarray
END IF
compiler option:
/nologo /debug:full /Od /Qcoarray:shared /warn:interfaces /module:"x64\Debug\\" /object:"x64\Debug\\" /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c
The executing time is 3 to 4 times more when using coarray than using optimization with option /o2. I think all threads are used in option /Qcoarray:shared, and extra optimization could not work.
How should I use optimization in the most of the place, and use the coarray in the place which I wanted, as MPI?
