Coarrays and defined assignment
Nick_M_3
Neuer Beitragender I
1.684Aufrufe
I don't think that this is right!  It's not polymorphic ....
MODULE Assign
    IMPLICIT NONE
    INTEGER :: factor
    TYPE, PUBLIC :: Mytype
        INTEGER :: comp = 123
    CONTAINS
        PROCEDURE, PRIVATE :: Copy
        GENERIC :: ASSIGNMENT (=) => Copy
    END TYPE Mytype
CONTAINS
    PURE SUBROUTINE Copy (a, b)
        CLASS(Mytype), INTENT(OUT) :: a
        CLASS(Mytype), INTENT(IN) :: b
        a%comp = b%comp*factor
    END SUBROUTINE Copy
END MODULE Assign
PROGRAM Main
    USE Assign
    IMPLICIT NONE
    TYPE(Mytype) :: coarray
  •     factor = THIS_IMAGE()
        SYNC ALL
        IF (THIS_IMAGE() == 1) THEN
            coarray = coarray[2]       ! (a)
            coarray[3] = coarray       ! (b)
            coarray[4] = coarray[5]    ! (c)
        END IF
    END PROGRAM Main
  • ifort version 14.0.2
    gerbil.f90(25): error #8392: If the actual argument is a polymorphic coindexed object, the dummy argument must not be polymorphic.   [COARRAY]
    gerbil.f90(26): error #8392: If the actual argument is a polymorphic coindexed object, the dummy argument must not be polymorphic.   [COARRAY]
    gerbil.f90(27): error #8392: If the actual argument is a polymorphic coindexed object, the dummy argument must not be polymorphic.   [COARRAY]
    compilation aborted for gerbil.f90 (code 1)
    2 Antworten
    Steven_L_Intel1
    Mitarbeiter
    1.684Aufrufe
    Hi, Nick.
    I agree with you that this error message is unwarranted. I'll note that defined assignment, per se, isn't relevant as you can see the same issue if you call Copy directly. I have escalated this as issue DPD200359259 and will let you know of any progress.
    Steven_L_Intel1
    Mitarbeiter
    1.684Aufrufe
    We fixed the error message, but then found that the call doesn't work correctly. Working on that one....
    Antworten
