Coarrays and defined assignment
Nick_M_3
I don't think that this is right!  It's not polymorphic ....
MODULE Assign
    IMPLICIT NONE
    INTEGER :: factor
    TYPE, PUBLIC :: Mytype
        INTEGER :: comp = 123
    CONTAINS
        PROCEDURE, PRIVATE :: Copy
        GENERIC :: ASSIGNMENT (=) => Copy
    END TYPE Mytype
CONTAINS
    PURE SUBROUTINE Copy (a, b)
        CLASS(Mytype), INTENT(OUT) :: a
        CLASS(Mytype), INTENT(IN) :: b
        a%comp = b%comp*factor
    END SUBROUTINE Copy
END MODULE Assign
PROGRAM Main
    USE Assign
    IMPLICIT NONE
    TYPE(Mytype) :: coarray
  •     factor = THIS_IMAGE()
        SYNC ALL
        IF (THIS_IMAGE() == 1) THEN
            coarray = coarray[2]       ! (a)
            coarray[3] = coarray       ! (b)
            coarray[4] = coarray[5]    ! (c)
        END IF
    END PROGRAM Main
  • ifort version 14.0.2
    gerbil.f90(25): error #8392: If the actual argument is a polymorphic coindexed object, the dummy argument must not be polymorphic.   [COARRAY]
    gerbil.f90(26): error #8392: If the actual argument is a polymorphic coindexed object, the dummy argument must not be polymorphic.   [COARRAY]
    gerbil.f90(27): error #8392: If the actual argument is a polymorphic coindexed object, the dummy argument must not be polymorphic.   [COARRAY]
    compilation aborted for gerbil.f90 (code 1)
    Hi, Nick.
    I agree with you that this error message is unwarranted. I'll note that defined assignment, per se, isn't relevant as you can see the same issue if you call Copy directly. I have escalated this as issue DPD200359259 and will let you know of any progress.
    We fixed the error message, but then found that the call doesn't work correctly. Working on that one....
