29657 Discussions
Code generation flags and automatic array confusion
Nathan
I'm attempting to understand stack overflows brought about by large statically-sized local arrays using ifort on linux. I hoped to produce a stack overflow error by reducing the stack size to 1000kb using "ulimit -s 1000" and then running a test program included below.
For reference, I compiled this program with gfortran using a variety of options and was given an output:
In sub1:              1200000
Segmentation fault (core dumped)
This makes sense to me. The compiler does not know the size of the array in sub1, so it allocates it to the heap.
However, compiling with ifort using three different flags:
ifort -qopenmp test.f90
ifort -recursive test.f90
ifort -auto  -heap-arrays 1500 test.f90
All three executables produce the output:
 In sub1:               1200000
 In sub2:               1200000
So, my question is, why is the second subroutine not producing a stack overflow?  I've tried using ifort 16.0.8 and 14.0.4 with similar results.
I would think that since the compiler knows the size of array p in sub2, it should put it on the stack, given the chosen options at compile time.
program test
  implicit none
  integer :: a
  a = 300000
  call sub1(a)
  call sub2(a)
end program
subroutine sub1(a)
  implicit none
  integer,intent(in) :: a
  integer,dimension(a) :: q
  print*, "In sub1:", sizeof(q)
  q = 0
end subroutine sub1
subroutine sub2(a)
  implicit none
  integer,dimension(300000) :: p
  print*, "In sub2:", sizeof(p)
  p = 0
end subroutine sub2
Thank you.
Steve_Lionel
ifort's default (-auto-scalars) is that local arrays are statically allocated (unless you made the procedure RECURSIVE or used -auto or some other option that implies -auto.) It's actually sub1 where I might expect a stack overflow, but the compiler probably realized that you never used the array and eliminated it.
Nathan
 Indeed the compiler seems to have foregone creating the array. Adding some random numbers and sums to the mix brought about the stack overflows I was expecting.  Thank you for your response.
