29533 Discussions
Code to write a registry (.reg) file
ferrad1
Nouveau contributeur I
7 543 Visites
A registry (.reg) file looks a little removed from a regular text, no doubt a lot to do with us of unicode, but also other strange bytes.  Is there a bit of Fortran code which will write a .reg file in the required format?
0 Compliments
Steve_Lionel
Contributeur émérite III
7 448 Visites
You're writing with formatted output, which will always add a line terminator (CR-LF) at the end of each record. Using ADVANCE='NO' doesn't stop this. The only way to avoid getting the terminators is to use unformatted, stream output.
Voir la solution dans l'envoi d'origine
0 Compliments
13 Réponses
andrew_4619
7 528 Visites
You can write all ask plain text, binary records have a type deliminator and then comma separated hex values. A simple reg file write could be 10 lines of code. Look at the wiki page.
0 Compliments
ferrad1
7 511 Visites
Ok, I've written a .reg file which writes an identical file to the one that is exported from regedit, with exception of an extra 0D0A at the end of the file.  I tried ADVANCE=NO in the format statement, but it still writes these extra 2 bytes.
Any idea how to suppress them?
0 Compliments
Steve_Lionel
7 496 Visites
Use ACCESS='STREAM' and FORM='UNFORMATTED' to write direct binary.
0 Compliments
ferrad1
7 474 Visites
I tried access='stream' and form='unformatted' but I still get the stray 0d 0a at the end of the file.
Reg files attached (renamed as .txt)
0 Compliments
andrew_4619
7 465 Visites
Both files have CR LF  (0D00 0A00) twice at the end in double byte character format (Bigendian) but in the one you write an additional CRLF  (0D0A) is output in single byte format at the end. However I an not trusting anything I see in a text editor I would want to read type bytes as a stream byte by byte and check that.
0 Compliments
ferrad1
7 459 Visites
Yes, the file I write has an extra od oa at the end (which I don't write).  The regedit exported one doesn't.
I look at them in https://hexed.it/
0 Compliments
andrew_4619
7 452 Visites
Well I am not sure what is happening here. When I write a text file from Fortran I get an ANSI/UTF-8 file with single byte characters. Your file is double byte encoded and then has a EOF in single byte format. But the Fortran runtime as I see it only supports ANSI for formatted (text) files.  Do you gave an example code a few lines showing the open, write and close so we can test/replicate? Someone else may be able to see the problem but I think I would need to plod through step by step through what you are doing.
0 Compliments
ferrad1
7 450 Visites
Here is the code, with the middle portion stripped out, but you can get the idea:
      open(unit=2,file='aqreg.reg',status='unknown')
      write(2,'(a)',advance='no') &
      char(z'ff')//char(z'fe')//char(z'57')//char(z'00')//char(z'69')//char(z'00')//char(z'6e')//char(z'00')//char(z'64')//char(z'00')//char(z'6f')//char(z'00')//char(z'77')//char(z'00')//char(z'73')//char(z'00')//&
      char(z'0d')//char(z'00')//char(z'0a')//char(z'00')//char(z'0d')//char(z'00')//char(z'0a')//char(z'00')
      close(unit=2)
0 Compliments
Steve_Lionel
7 449 Visites
0 Compliments
ferrad1
7 433 Visites
I still get the 0d 0a:
      open(unit=2,file='aqcomp.inc',status='unknown',access='stream',form='unformatted')
      write(2) ecstring
      close(unit=2)
ecstring is of length 55
0 Compliments
IanH
7 421 Visites
The most recent file is not remotely something that the registry editor would accept for an import.
I cannot reproduce the extra CR-LF using a recent compilers.
(Use of a hardcoded unit number below 10 makes me nervous - prefer a value obtained using the NEWUNIT specifier, but that does not appear to be the issue here.)
The registry editor will import "ansi" encoded files (as would be written by normal/boring Fortran formatted write statements), so none of this should be necessary.  When checking the results of an import, be mindful of registry redirection - are you looking in the right place?
(From a Fortran language point of view, the easiest way to write UTF-16LE encoded files is via an appropriate ENCODING specifier in the OPEN statement.  But Fortran processor support for different encodings is processor dependent, and the Intel Fortran runtime does not support UTF-16LE encoding.)
0 Compliments
ferrad1
7 418 Visites
Yes I know this is not a registry file, I was just experimenting with dummy code.  I did run your code and I did not get the trailing 0d 0a, so it must be something in my code or compilation options.  Thanks for helping out.
0 Compliments
andrew_4619
7 485 Visites
When I export a .reg file I get a text file (on my system it is encoded UCS2 LE BOM but ANSI should be OK) with CRLF at the end of every line. Attach your 2 reg files you are comparing.
0 Compliments
Répondre
