29434 Discussions
Code works in IFORT and IFX/Release but crashes in IFX/Debug
Jarek_T
I have the following code:
program line_test
   implicit none
   integer :: i, arr(2,5), iv(2)
   do i = 1, 5
      iv = [i,i]
      arr(:,i) = i     ! ok statement
      arr(:,i) = iv    ! ok statement
      arr(:,i) = [i,i] ! statenment crashing the code
   end do
   write(*,*) 'testing succesfull'
end program
It is compiled in debugging mode with the following flags:
/nologo /debug:full /Od /warn:all /module:"x64\Debug\\" /object:"x64\Debug\\" /traceback /check:all /libs:dll /threads /dbglibs /c
When compiled and run  using Intel® Fortran Compiler 2024.0 IFORT I get expected results:
x64\Debug\line_test.exe
 testing succesfull
When compiled in Debug mode  using Intel® Fortran Compiler 2024.0 IFX I get an runtime error:
forrtl: severe (408): fort: (11): Subscript #1 of the array ARR has value 0 which is less than the lower bound of 1
Image              PC                Routine            Line        Source
line_test.exe      00007FF75E3F15CE  LINE_TEST                   9  line_test.f90
line_test.exe      00007FF75E3F16FB  Unknown               Unknown  Unknown
line_test.exe      00007FF75E3F1C19  Unknown               Unknown  Unknown
line_test.exe      00007FF75E3F1B32  Unknown               Unknown  Unknown
line_test.exe      00007FF75E3F19EE  Unknown               Unknown  Unknown
line_test.exe      00007FF75E3F1C8E  Unknown               Unknown  Unknown
KERNEL32.DLL       00007FF9EF8F257D  Unknown               Unknown  Unknown
ntdll.dll          00007FF9F058AF28  Unknown               Unknown  Unknown
Code also works fine when compiled in Release mode using Intel® Fortran Compiler 2024.0 IFX compiler with the following flags:
/nologo /O2 /module:"x64\Release\\" /object:"x64\Release\\" /libs:dll /threads /c
 Anybody knows why is the code crashing?
andrew_4619
I am pretty sure I posted about a very similar issue not long ago but I am struggling to find it....
[edit: found it]
https://community.intel.com/t5/Intel-Fortran-Compiler/Exception-in-IFX-2024-2-0-Intel-R-64/m-p/1610145#M172758
andrew_4619
[edit: found it]
Jarek_T
Yes it does sound like the same issue, with rather unsatisfactory solution of "I escalated this report to our compiler engineering", but without any info about their findings or plans for fixing it.
TobiasK
@Jarek_T
I think your expectations are too high. The bug was reported not so long ago. It's added to the list of bugs that we will fix. Unfortunately, we also have to prioritize on which bugs to work first. Several factors play a role when prioritizing bugs. As you might know, we also offer priority support for those customer who want to have their bugs assigned and worked on with higher priority.
That being said, we are very happy to take up bugs from the community and are very proud of the Fortran community here.
Jarek_T
You are probably right about my expectations. Only recently I started working again with fortran, and the last couple decades I was working with languages where compiler/interpreter errors are super rare and each one is a big deal. I do not recall ever finding one in python, R, C++ or lua and the last one I found in Matlab was probably 15 years ago.  So it is a bit jarring to find 2 compiler errors in couple months in IFX compiler.
andrew_4619
Moving Forward (Development) = Bugs, a fact of life!
TobiasK
Not finding bugs for decades sound scary to me, smells like a ton of silent bugs.
Jarek_T
I agree. Fortran is changing a lot, while trying to be backward-compatible, which sounds like a hard task. I love the new features of the language, which allow creation of much more readable (=maintainable)  code, and those will come at the price of bugs.
Thank you all for the help with this.
Devorah_H_Intel
@Jarek_T  - thank you for the report and test case. I have added your test case to the existing internal bug report. There is no fix in the upcoming 2025 release, but we plan on fixing it in future ifx releases.
Francesco_F
waiting for the bug fix, you may try using double brackets (it probably depends on the rank of your array):
arr(:,i) = [ [ i,i] ]
It is definitely not a good solution if the problem is repeated in too many lines of your code
