29391 Discussions
Code works in IFORT but crashes in IFX
Jarek_T
I have the following code:
module mesh_mod
   implicit none
   private
   type, public :: ivec_type
      integer, allocatable :: iv(:)
   end type
   public :: jagged_array_3D
contains
   function jagged_array_3D(n) result(jag)
      implicit none
      integer,  intent(in)  :: n
      type(ivec_type), allocatable :: jag(:) ! output
      integer :: i
      allocate( jag(n) )
      do i = 1, n
         allocate( jag(i) % iv(i-1 ) )
         jag(i) % iv = i
      end do
      write(*,*) 'exiting jagged_array_3D'
   end function
end module
program mesh_test
   use mesh_mod, only: jagged_array_3D, ivec_type
   implicit none
   integer :: i
   write(*,*) 'test #1'
   jag = jagged_array_3D(3)
   do i = 1, size(jag)
      write(*,*) '  jag', i, '|', jag(i) % iv
   end do
   ! test 2
   write(*,*) 'test #2'
   call test2()
   write(*,*) 'testing succesfull'
contains
   subroutine test2()
      use mesh_mod, only: ivec_type, jagged_array_3D
      implicit none
      integer :: i
      do i = 1, size(jag)
      end do
      deallocate(jag)
   end subroutine
end program
It is compiled in debugging mode with the following flags: /nologo /debug:full /Od /heap-arrays1000 /warn:all /Qinit:snan /Qinit:arrays /module:"x64\Debug\\" /object:"x64\Debug\\" /Fd"x64\Debug\vc170.pdb" /traceback /check:all /libs:dll /threads /dbglibs /c
When compiled and run  using Intel® Fortran Compiler 2024.0 IFORT I get expected results:
x64\Debug\mesh_test.exe
 test #1
   jag           1 |
   jag           2 |           2
   jag           3 |           3           3
 test #2
   jag           1 |
   jag           2 |           2
   jag           3 |           3           3
 testing succesfull
When compiled and run  using Intel® Fortran Compiler 2024.0 IFX I get an error:
 test #1
   jag           1 |
   jag           2 |           2
   jag           3 |           3           3
 test #2
forrtl: severe (157): Program Exception - access violation
Image              PC                Routine            Line        Source
libifcoremdd.dll   00007FFA37AF06FB  Unknown               Unknown  Unknown
libifcoremdd.dll   00007FFA37AF164F  Unknown               Unknown  Unknown
libifcoremdd.dll   00007FFA37AF0872  Unknown               Unknown  Unknown
libifcoremdd.dll   00007FFA37AF09D3  Unknown               Unknown  Unknown
mesh_test.exe      00007FF7DABE2E7C  TEST2                      57  mesh_test.f90
mesh_test.exe      00007FF7DABE27F0  MESH_TEST                  44  mesh_test.f90
mesh_test.exe      00007FF7DABE36EB  Unknown               Unknown  Unknown
mesh_test.exe      00007FF7DABE3BF9  Unknown               Unknown  Unknown
mesh_test.exe      00007FF7DABE3B1E  Unknown               Unknown  Unknown
mesh_test.exe      00007FF7DABE39DE  Unknown               Unknown  Unknown
mesh_test.exe      00007FF7DABE3C6E  Unknown               Unknown  Unknown
KERNEL32.DLL       00007FFAE4A07374  Unknown               Unknown  Unknown
ntdll.dll          00007FFAE50BCC91  Unknown               Unknown  Unknown
Anybody knows why is the code crashing in IFX?
Devorah_H_Intel
I tested it internally and the issue will be resolved in the next 2025 ifx release.
jimdempseyatthecove
      do i = 1, n
         jag(i) % iv = i
      end do
When i==1 you are allocating iv with size 0.
Is it valid to initialize an (allocatable) array with size 0?
What does it mean to "set all values of a null array to x"?
What do you expect to happen when you later attempt to verify if x is in the array?
If the use is valid, then I suggest you add:
      do i = 1, n
         if(i==1) print *,"Before allocate"
         if(i==1) print *,"before assign"
         jag(i) % iv = i
      end do
This would narrow done if the issue were due to:
or
null array = value
Jim Dempsey
Jim Dempsey
Jarek_T
Jim, Thank you for looking into it. The code is doing what is intended, which is mimic behavior of much larger code which creates jagged array output, with some rows having zero length. According to some Fortran forums modern Fortran is OK with allocating zero size arrays which you can later test with "size" function. I agree that setting zero size array to some value makes little sense and is not something I am doing in the real code,  so I changed the loop in my toy example to
      do i = 1, n
         if (i>1) jag(i) % iv = i
      end do
Which made no difference in the running of the code.
I also removed /Qinit:snan /Qinit:arrays compiler options, also without any change in the code performance.
My current options are : /nologo /debug:full /Od /heap-arrays1000 /warn:all /module:"x64\Debug\\" /object:"x64\Debug\\" /Fd"x64\Debug\vc170.pdb" /traceback /check:all /libs:dll /threads /dbglibs /c"
By the way, the crash occurs after  call to jagged_array_3D function is done, while it is returning to line 57.
GVautier
New Contributor III
It looks like a stack corruption.
jimdempseyatthecove
This is correct.
The issue is with the NullArray = Scalar initialization.
Is this defined in the specification?
Is this a NOOP
.or.
Seeing that the Null Array is also Alocatable, would this make the array size(1), iow allocate it to the size of the RHS?
From my understanding, result(jag) makes jag intent(out) as indicated by your comment.
Function outputs, in this case an array of UDT, create a temporary object (array of UDT), then on return, copies the temporary array to the LHS allocatable array. Your jag = jagged_array_3D(3statement.
I recall a similar (same) instance of this problem, and the solution was to use a subroutine
    call jagged_array_3D(3, jag
where the dummy jag is declared as "allocatable, intent(inout)".
I do not recall if the consensus was if the function format was within the standards or not.
Jim Dempsey
Jarek_T
I eliminated this operation with performing the assignment only when array is of non-zero size
Yes, the code works when using subroutine. However I wanted to understand if I am doing something wrong here or is this a compiler bug.
In the project I am working on, I spend a lot of time analyzing different subroutines of a legacy code trying to figure out what are input and output variables. Once I figure it out I add "intent" statements and if they have a single output I usually convert them to functions, ideally PURE functions, which I find easier to read. This is the first time when there is a difference between function and subroutine, or between IFORT and IFX, and I want to make sure I am not doing something illegal in Fortran.
The issue is only with IFX and I usually do not use IFX as the compiled release code is much slower then the same code compiled with IFORT. However, I run my unit testing in both, just in case.
johnstunt
Initializing an allocatable array with size 0 is valid but results in an empty array; setting all values to `x` has no effect, and verifying if `x` is in the array will always return false. If valid, add a check to handle empty arrays.
Andrew_Smith
Valued Contributor I
The posters original code runs fine with IFX 2024.2.1 on Windows
Jarek_T
I installed IFX 2024.2.1 on my Windows machine and still have the same issue:
Code:
module mesh_mod
   implicit none
   private
   end type
contains
   function jagged_array(n) result(jag)
      implicit none
      integer :: i
      allocate( jag(n) )
      do i = 1, n
      end do
      write(*,*) 'exiting jagged_array'
   end function
end module
program mesh_test
   use mesh_mod, only: jagged_array, ivec_type
   implicit none
   integer :: i
   jag = jagged_array(3)
   do i = 1, size(jag)
   end do
   ! test
   call test2()
contains
   subroutine test2()
      implicit none
      integer :: i
      do i = 1, size(jag)
      end do
      deallocate(jag)
   end subroutine
end program
Compiler options:
/nologo /debug:full /Od /heap-arrays1000 /warn:all /module:"x64\Debug\\" /object:"x64\Debug\\" /traceback /check:all /libs:dll /threads /dbglibs /c
Compiling output:
1>------ Build started: Project: mesh_test (IFX), Configuration: Debug x64 ------
Compiling with Intel® Fortran Compiler 2024.2.1 [Intel(R) 64]...
mesh_test.f90
Linking...
Embedding manifest...
Build log written to  "file://C:/projects/Das_Boot/mesh_test4/x64/Debug/BuildLog.htm"
mesh_test - 0 error(s), 0 warning(s)
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
========== Build completed at 12:19 PM and took 04.441 seconds ==========
Run output:
 test #1
   jag           1 |
   jag           2 |           2
   jag           3 |           3           3
 test #2
libifcoremdd.dll   00007FF923C6070C  Unknown               Unknown  Unknown
libifcoremdd.dll   00007FF923C6164F  Unknown               Unknown  Unknown
libifcoremdd.dll   00007FF923C60872  Unknown               Unknown  Unknown
libifcoremdd.dll   00007FF923C609D3  Unknown               Unknown  Unknown
mesh_test.exe      00007FF6F0D62EA7  TEST2                      57  mesh_test.f90
mesh_test.exe      00007FF6F0D6281F  MESH_TEST                  44  mesh_test.f90
mesh_test.exe      00007FF6F0D6370B  Unknown               Unknown  Unknown
mesh_test.exe      00007FF6F0D63C29  Unknown               Unknown  Unknown
mesh_test.exe      00007FF6F0D63B42  Unknown               Unknown  Unknown
mesh_test.exe      00007FF6F0D639FE  Unknown               Unknown  Unknown
mesh_test.exe      00007FF6F0D63C9E  Unknown               Unknown  Unknown
KERNEL32.DLL       00007FF9458E257D  Unknown               Unknown  Unknown
ntdll.dll          00007FF94792AF28  Unknown               Unknown  Unknown
Maybe the difference is in compiler options.
Jarek_T
Actually removing "/heap-arrays1000" compiler option fixed the issue.
My new compiler options:
/nologo /debug:full /Od /warn:all /module:"x64\Debug\\" /object:"x64\Debug\\" /traceback /check:all /libs:dll /threads /dbglibs /c
My new run output:
 test #1
   jag           1 |
   jag           2 |           2
   jag           3 |           3           3
 test #2
   jag           1 |
   jag           2 |           2
   jag           3 |           3           3
 testing succesfull
I assume it is some sort of IFX compiler bug. Anybody knows how to report them?
Devorah_H_Intel
