Com Server and Global Variables
hweisberg
To restate my question of 3/18/03:
The COM standard supports various options, including MultiUse, GlobalMultiUse, SingleUse, and GlobalSingleUse. I used the CVF COM wizard to create a COM server, and it appeared to behave as MultiUse or GlobalMultiUse. This is no good because we need to create instances of our FORTRAN COM object in a multi-user client-server environment. All the variables in our COMMON blocks must be independent for each instance.
Can the COM Wizard create a COM server that behaves similar to SingleUse?
