thanks for your reply,
It is a setting in: Project->Properties->Configuration Properties-> General-> Common Language Runtime Support
As far as I understand it, /clr:pure does not allow you to use unmanaged classes. Full setting is "Pure MSIL Common Language Runtime Support (/clr:pure)"
It is the default setting when creating a newWindows Forms project (VC++ 2005).Weare experiencing some strange errors with the designview and the "/clr" option so I was wondering if it would be possible to switch back to "/clr:pure" and still include and use a .dll generated with CVF.
In short: Can I include and use a .dll withmanaged C++only?
best regards,
Jan
For whoever is interested, repost and answer can be found here
(seems I have been to quick with some assumptions..)
Jan
