Command line requirements
Intel_C_Intel
Microsoft Visual C++* not found.
Microsoft Visual C++. NET 2002 or 2003 is required to install Intel Visual Fortran Compiler for 32-bit applications.
Since this product requires some important components (linker) of Microsoft Visual C++, command line support will not function if you continue installing.
What "minimum components" of VS (7.0, 7.1 or8.0) I must have to be able fully work with ifort?
Visual C++. You can also use the free Visual C++ 2005 Express Edition with 9.1.
Intel_C_Intel
Thanks for answer.
If I'm not mistaking, IVFC 9.1 with VC++ EE will have only command-line mode plus it's beter to have Microsoft SDK.
Command line mode for development. Tour actual application can be any kind. Yes, you also need the PSDK.
