29386 Discussions
Comparison of two real numbers for equality
avinashs
One of the first things I was taught in my Fortran course some 30+ years ago was that testing two real variables (single or double precision) for equality was not reliable and that round-off errors may give a false result. On the other hand, comparing two integers is always accurate. Does this rule still hold true for real variables? In particular, will the following code always produce the correct result. I am willing to accept numbers that differ by less than epsilon(1.0d0) to be considered equal.
program main
real(kind = :: a(10), b(10)
a = 1.0d0
b = 1.0d0
if (all(a == b)) then
print *, 'arrays are have equal values'
else
print *, 'arrays are different'
end if
read *
end program main
JohnNichols
Valued Contributor III
You should always set a delta for the numbers and accept if abs(a-b) < delta then equal -- otherwise not really reliable
JohnNichols
