Compatibility problem
anamika_shrivastava_
Respected sir,
I am trying to download WRf version 3.0 on my server. I have using Intel 9.0 compiler and netcdf-3.6.2. but I am getting error. Is WRFV3 is compatible with Intel9.0 and netcdf-3.6.2? I am getting error like
IPO error :unresolved:mpi_init_
IPO Error: unresolved : mpi_init_
Referenced in parallel_module.o
IPO Error: unresolved : mpi_comm_rank_
IPO Error: unresolved : mpi_comm_size_
IPO Error: unresolved : mpi_recv_
IPO Error: unresolved : mpi_send_
IPO Error: unresolved : mpi_bcast_
IPO Error: unresolved : mpi_finalize_
IPO Error: unresolved : mpi_abort_
IPO Error: unresolved : mpi_dup_fn_
IPO Error: unresolved : mpi_null_delete_fn_
IPO Error: unresolved : mpi_null_copy_fn_
IPO Error: unresolved : mpi_comm_dup_fn_
IPO Error: unresolved : mpi_comm_null_delete_fn_
IPO Error: unresolved : mpi_comm_null_copy_fn_
IPO Error: unresolved : mpi_win_dup_fn_
IPO Error: unresolved : mpi_win_null_delete_fn_
IPO Error: unresolved : mpi_win_null_copy_fn_
IPO Error: unresolved : mpi_type_dup_fn_
IPO Error: unresolved : mpi_type_null_delete_fn_
IPO Error: unresolved : mpi_type_null_copy_fn_
IPO Error: unresolved : mpi_conversion_fn_null_
I am not getting any view why this error is coming please help . and tell me What should i do?
Thanku sir. plz Reply soon.
Kevin_D_Intel
I do not see that we have built the newer WRF 3.x release with the older9.0 compiler to know if it is compatible or not, but that's not the issue you have shown. The errors suggest the link did not include the required MPI libraries.
Judging from the WRF Knowledge Base article here that I referred to in your earlier post, you must setup your environment accordingly for the MPI implementation you are using, and then run the WRF configure script.
If the MPI libraries were missing from the link as the errors suggest, then that may suggest your environment was not properly initialized with the required MPI settings before the WRF configure script was run. You might review the steps in the Knowledge Base article again and repeat the steps starting at step 2.
I also think you should consider using a newer compiler release with this newer version of WRF.
