Compilation crash
Volodymyr_K_
Compiler crashes with the message
20000_0
: catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for w.f90 (code 1)
Someody can suggest workaround?
openSsuSE 12.1, 12.2
Intel Fortran 12.1, 13.0 for Linux/64
Heinz_B_Intel
I will investigate the issue and will come back to you
Heinz_B_Intel
I escalated the compiler fault to engineering: Internal tracking id is DPD20023780. I will let you know when a fix will be available. The problem is triggered by the PROCEDURE POINTER construct in line 46 etc. I don't have a workaround yet ( except not usign these pointers) but will check again with the compiler devlopers.
Heinz_B_Intel
The problem has been fixed by the 14.0 compiler
