29650 Discussions
Compilation error using VS2019 Build Tools
Sid91
Hi, I'm trying to compile a fortran 77 code with ifort but I get this error :
LINK : fatal error LNK1104: impossible d'ouvrir le fichier 'ifconsol.lib'
I'm doing this from a VS2019 build tools developer powershell command.
hope you can help, regards
Sid
Arjen_Markus
Do you (re)compile the complete code or do you use some libraries that were built previously? Can you show us the command-line you are using?
We should determine where the reference to ifconsol.lib is coming from.
Steve_Lionel
Also, show us all the text from the start of the command session to where you issue the ifort command. Using ifort from a Powershell window is tricky - what I found works best is to start with the cmd.exe shortcut Intel installs in the Start menu, and then type "powershell" to start a ps session, keeping all of the paths and environment variables intact.
