29642 Discussions
Compilation error when using Class(*), Intent (out)
Vasili_M_
Have written a routine to convert a character to integer
    Integer :: j
    Write (*,*) '# Call str_to_num ("12", j)'
    Write (*,*) "j: ", j
I am using class(*) and getting error
    Program received signal 11 (SIGSEGV): Segmentation fault.
However when I change `Class(*)` with `Integer`, I do get
`" Subroutine str_to_num"` being printed.
Furthermore, changing to `Intent(inout)` rather than `Intent(out)` gets
the routine to work
    Subroutine str_to_num  &
     s, num, fmt, wrn            &
    Character (len=*), Intent (in) :: s
    Character (len=*), Intent (in), Optional :: fmt
    Class (*), Intent (out) :: num
    Character (len=*), Intent (inout), Optional :: wrn
    Integer :: ios
    Character (len=65) :: frmt
    Write (*,*) " Subroutine str_to_num"
     Select Type (num)
       Type Is (Integer)
         Read (s, *, iostat=ios) num
       Type Is (Real)
       Type Is (Double Precision)
       Type Is (Real(Real128))
     End Select
    End Subroutine
First, this is not a compilation error - it's a runtime error. Second, if you got the error you indicated you're running on Linux, and this is the Windows forum. Third, your code excerpt did not show that the caller had an explicit interface for the subroutine - this is required if a dummy argument is polymorphic. If I make sure there is one, the program works for me.
Vasili_M_
Apologies, you are correct Steve.
