29620 Discussions
Compilation fails when using intel compilers for Fortran ctest example
qqqqq
On the HPC system I'm using, I'm trying out the ctest example for Fortran from https://github.com/dryman/fortran_unit_test/tree/main.
As in the repository README example, I have a file `my_tests.f90` that looks like
! my_tests.f90
module my_tests_mod
use iso_fortran_env
use iso_c_binding
implicit none
contains
integer function my_test_success() result(ret) bind(C)
ret = 0
end function my_test_success
integer function my_test_fail() result(ret) bind(C)
ret = 1
end function my_test_fail
end module my_tests_mod
and the `CMakeLists.txt` is
cmake_minimum_required(VERSION 3.18)
project(cmake_test)
enable_language(Fortran)
enable_testing()
set(TEST_LIST
my_test_success
my_test_fail
create_test_sourcelist(_ my_tests_main.c ${TEST_LIST})
add_executable(my_tests my_tests_main.c my_tests.f90)
foreach (test ${TEST_LIST})
add_test(NAME ${test} COMMAND my_tests ${test})
endforeach ()
Running `cmake -B build` and `cmake --build build` successfully compiles the project when using gfortran. However, when I use the intel compilers that are installed on my HPC system, it doesn't work. This is the output and error that I'm getting:
$ cmake -B build
-- The C compiler identification is IntelLLVM 2023.2.0
-- The CXX compiler identification is IntelLLVM 2023.2.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler:PATH_TO_INTEL_ONEAPI/intel-oneapi-compilers-2023.2.1-qlb6hkr3iyhanhvq4oycb562sskibrff/compiler/2023.2.1/linux/bin/icx - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler:PATH_TO_INTEL_ONEAPI/intel-oneapi-compilers-2023.2.1-qlb6hkr3iyhanhvq4oycb562sskibrff/compiler/2023.2.1/linux/bin/icpx - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- The Fortran compiler identification is IntelLLVM 2023.2.0
-- Detecting Fortran compiler ABI info
-- Detecting Fortran compiler ABI info - done
-- Check for working Fortran compiler:PATH_TO_INTEL_ONEAPI/intel-oneapi-compilers-2023.2.1-qlb6hkr3iyhanhvq4oycb562sskibrff/compiler/2023.2.1/linux/bin/ifx - skipped
-- Checking whetherPATH_TO_INTEL_ONEAPI/intel-oneapi-compilers-2023.2.1-qlb6hkr3iyhanhvq4oycb562sskibrff/compiler/2023.2.1/linux/bin/ifx supports Fortran 90
-- Checking whetherPATH_TO_INTEL_ONEAPI/intel-oneapi-compilers-2023.2.1-qlb6hkr3iyhanhvq4oycb562sskibrff/compiler/2023.2.1/linux/bin/ifx supports Fortran 90 - yes
-- Configuring done
-- Generating done
-- Build files have been written to: PATH_TO_INTEL_ONEAPI/cmake_test/build
$ cmake --build build
Scanning dependencies of target my_tests
[ 33%] Building Fortran object CMakeFiles/my_tests.dir/my_tests.f90.o
[ 66%] Building C object CMakeFiles/my_tests.dir/my_tests_main.c.o
[100%] Linking Fortran executable my_tests
ld: CMakeFiles/my_tests.dir/my_tests_main.c.o: in function `main':
my_tests_main.c:(.text+0x0): multiple definition of `main'; PATH_TO_INTEL_ONEAPI/intel-oneapi-compilers-2023.2.1-qlb6hkr3iyhanhvq4oycb562sskibrff/compiler/2023.2.1/linux/compiler/lib/intel64_lin/for_main.o:for_main.c:(.text+0x0): first defined here
ld: PATH_TO_INTEL_ONEAPI/intel-oneapi-compilers-2023.2.1-qlb6hkr3iyhanhvq4oycb562sskibrff/compiler/2023.2.1/linux/compiler/lib/intel64_lin/for_main.o: in function `main':
for_main.c:(.text+0x19): undefined reference to `MAIN__'
gmake[2]: *** [CMakeFiles/my_tests.dir/build.make:112: my_tests] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:83: CMakeFiles/my_tests.dir/all] Error 2
gmake: *** [Makefile:101: all] Error 2
TobiasK
@qqqqq
Please give more details on how you set the compiler to ifx/icx. This looks wrong: (note the PATH_TO_INTEL_ONEAPI)
second, please use cmake -DCMAKE_VERBOSE_MAKEFILE:BOOL=ON to see what is actually happening
third, please use the latest icx/ifx compiler 2025.0.4.
