29649 Discussions
Compilation using IFORT rather than IFX?
AONym
New Contributor II
How do I force compilation using IFORT rather than IFX, when using VS2022?
IFX doesn't support /check:uninit.
AONym
New Contributor II
I found the answer--right-click in the project in solution explorer and select 'Intel compiler'. It does not seem to be available in VS under Tools/Options/Intel Fortran.
Now all I have to do is figure out how to avoid getting a message
"ifort: remark #10448: Intel(R) Fortran Compiler Classic (ifort) is now deprecated and will be discontinued late 2024."
for every file compiled.
andrew_4619
/Qdiag-disable:7025,5142,6477,7762,10448
for example
