Compile Errors
cptfisher
Good Day,
I get the following errors when trying to compile a gateway mex file and I'm not sure why. Any help is appreciated:
aerocalc.f90(8): error #5082: Syntax error, found IDENTIFIER 'PLHS' when expecting one of: ( % [ : . = =>
mwpointer plhs(*), prhs(*)
aerocalc.f90(14): error #5082: Syntax error, found IDENTIFIER 'MXCREATEDOUBLEMATRIX' when expecting one of: ( % [ : . = =>
mwpointer mxcreatedoublematrix, mxgetpr
aerocalc.f90(15): error #5082: Syntax error, found IDENTIFIER 'MXGETM' when expecting one of: ( % [ : . = =>
mwpointer mxgetm, mxgetn
aerocalc.f90(17): error #5082: Syntax error, found IDENTIFIER 'TURBINECOMPONENTS_PR' when expecting one of: ( % [ : . = =>
mwpointer turbinecomponents_pr, y_pr
aerocalc.f90(20): error #5082: Syntax error, found IDENTIFIER 'M' when expecting one of: ( % [ : . = =>
mwpointer m, n
aerocalc.f90(21): error #5082: Syntax error, found IDENTIFIER 'SIZE' when expecting one of: ( % [ : . = =>
mwsize size
mecej4
You probably did not add
include 'fintrf.h'
to your source file or, if you are using C style includes, did not specify that the C preprocessor shoud be used.
By themselves (i.e., without the header file defining 'mwpointer') the lines that you show are not valid Fortran declarations.
mecej4
include 'fintrf.h'
JVanB
Valued Contributor II
try replacing mwpointer and mwsize with INTEGER(INT_PTR_KIND())
cptfisher
It worked. I forgot about including that tag. Thanks
