Compile Remark 5418 USEROPEN
mattintelnetfort
I'm trying to compile a source file but keep getting the following remark. The code links and runs as expected but cannot get rid of the 'remark' without changing project settings. I don't want to change project settings because of other code in source. Is there a way to simply treat the problem lines without changing project/file properties? Thanks.
remark #5418: USEROPEN routine must be defined with C or Default calling convention
EXTERNAL FTN_FILE_OPEN
The code snippet generating this is:
OPEN (LU, FILE=CSPEC, ACCESS=CAC, USEROPEN=FTN_FILE_OPEN, ERR=6000)
Do you have CVF set as the default calling convention? If so, then you'll have to do this:
Add the line:
!DEC$ ATTRIBUTES DEFAULT :: FTN_FILE_OPEN
two places. One, after the EXTERNAL and the other in the source of FTN_FILE_OPEN.
