29653 Discussions
Compile in Linux, run on Windows XP?
yeohakoon
I need to share the executable file of a Fortran programme, which was compiled on a Linux machine (CentOS), but most of my colleagues are using Windows XP.
Any possibility of setting the compiler options so that my colleagues could run the executable file on Windows XP?
sphost
MinGW can be used for application compiled with gcc or g++ but for ifort ...
In my opinions you have to recompile your code on a windows system using the ifort compiler for windows
Maybe some special tools exist for ifort but I don't know them.
Nicolae_P_Intel
There is the option of cross compiling on Linux for Windows (or other platform) but it needs some time to set up the cross compiling chain. I did that in the past with gcc and I am not aware if the fortran compilers are also able to do that.
Hope it helps.
Nick
ifort does not have such an option. The executable format and calling conventions are different between the two operating systems.
