29376 Discussions
Compile issue in Win, but not in Linux
Amedick__Volker
My small test program compiles, links and run fine in Linux. But when I try to do the same think in Windows 7 I get a compiler error. What am I doing wrong? I quite new to Windows programming. My final target is to use a generic module interface from a dll.
  • Compiler command Linux:
> ifort -c jochen_mod.f90 -fpic -shared -o libjochen.so
> ifort  peter.f90 -I. -L. -ljochen
> ./a.out
 I am a Integer
 I am a Real
 I am a Real
  • Under Windows 7 the module compiles fine but compiling the main program peter.f90 gives the following error message:
>ifort /c peter.f90 /I.
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.8.254 Build 20180409
Copyright (C) 1985-2018 Intel Corporation.  All rights reserved.
peter.f90(28): error #6401: The attributes of this name conflict with those made accessible by a USE statement.   [GETVALUE]
    i = getValue(i)
peter.f90(29): error #6401: The attributes of this name conflict with those made accessible by a USE statement.   [GETVALUE]
    r = getValue(r)
compilation aborted for peter.f90 (code 1)
  • Main program 'peter':
program peter
    use jochen_mod, only    : getValue
    implicit none
    ! Variables
    integer     :: i = 1
    real        :: r = 1.0
    ! Body of peter
    i = getValue(i)
    r = getValue(r)
end program peter
  • Module jochen_mod:
module jochen_mod
    implicit none
    private
    public getValue
    interface getValue
        module procedure getValueI
        module procedure getValueR
    end interface getValue
    contains
    function getValueI(i) result(r)
        integer, intent(in) :: i
        real                :: r
        print*, "I am an Integer"
        r = float(i)
        r = getValue(r)
    end function getValueI
    function getValueR(ri) result(r)
        real, intent(in)    :: ri
        real                :: r
        print*, "I am a Real"
        r = ri
    end function getValueR
end module jochen_mod
Steve_Lionel
Take out the line !DEC$ ATTRIBUTES DLLIMPORT :: getValue - you don't need it and it is what is interfering. The DLLEXPORT in the module turns into a DLLIMPORT automatically on USE.
Here is what I see when I remove the line:
D:\Projects>ifort p.f90 j.lib
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.1.144 Build 20181018
Microsoft (R) Incremental Linker Version 14.16.27024.1
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:p.exe
-subsystem:console
p.obj
j.lib
D:\Projects>p.exe
 I am an Integer
 I am a Real
 I am a Real
Steve_Lionel
I just tried this with the current version 19 and got no errors. You didn't show compiling the module on Windows, but I assume you did it the same way as on Linux.
Amedick__Volker
Hi Steve,
thanks for the quick response. Actually I noticed that the I pasted the wrong code producing the error. If I pick the code as posted it compiles and links fine under Win7 with compiler v2016. But when I launch the executable an error message pops up: 'The application was unable to start correctly (0xc....). Click OK to close the application').
The code creating the error message contained lines with !DEC? Attributes. So here is the code producing the error messages.
  • The module jochen_mod.f90
I used the following compile options:
> <Path\to>\compilervars.bat intel64
> ifort  /dll jochen_mod.f90
module jochen_mod
    implicit none
    private
    public getValue
    interface getValue
    contains
        !DEC$ ATTRIBUTES DLLEXPORT :: getValueI
        !dec$ attributes reference:: i
        real                :: r
        r = float(i)
        r = getValue(r)
        !DEC$ ATTRIBUTES DLLEXPORT :: getValueR
        !dec$ attributes reference:: ri
        real                :: r
        r = ri
  • Main program peter.f90
command line to just compile the main program:
> ifort  /c /I. peter.f90
program peter
    implicit none
    ! Variables
    integer     :: i = 1
    real        :: r = 1.0
    !real        :: getValue
    ! Body of peter
    i = getValue(i)
    r = getValue(r)
end program peter
This results in the following error message (as in my 1st post):
) 64, Version 16.0 Build 20180409
    i = getValue(i)
    r = getValue(r)
Sorry for the confusion. But as described, none of the approaches, w/ and w/o the !DEC? statements, produces a working result.
Thanks in advance,
Volker
Lorri_M_Intel
You shouldn't need the "dllimport getvalue" in your file peter.f90.   The "dllexport"s in the module file should be "magically" turned into dllimport when the module is USEd.
Take out that line, and then please post the link command you used to build the application.
                   thanks -
                                  --Lorri
Steve_Lionel
-out:p.exe
-subsystem:console
p.obj
j.lib
D:\Projects>p.exe
 I am an Integer
 I am a Real
 I am a Real
Steve_Lionel
Oh, and the reason for the OS difference is that the Linux compiler ignores DLLIMPORT/DLLEXPORT.
Amedick__Volker
Dear all,
this solved the issue. It is working now for me as well. Here are the commands I used to finally run the executable peter.exe including the terminal output:
>c:"\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\bin\compilervars.bat" ia32
Copyright (C) 1985-2016 Intel Corporation. All rights reserved.
Intel(R) Compiler 16.0 Update 8 (package 254)
Intel(R) Visual Fortran Compiler for applications running on IA-32, Version 16.0
 Build 20180409
Microsoft (R) Incremental Linker Version 11.00.61030.0
-out:jochen_mod.dll
-dll
-implib:jochen_mod.lib
jochen_mod.obj
   Creating library jochen_mod.lib and object jochen_mod.exp
>ifort  peter.f90 jochen_mod.lib
 Build 20180409
-out:peter.exe
-subsystem:console
peter.obj
jochen_mod.lib
>peter.exe
 I am an Integer
 I am a Real
 I am a Real
