Compile module with fotran code
james_uta
I have a fortran code including module files and fortran source code files as follows
main.f
PROGRAM MAIN
USE MODDULECOM
USE MODDULEPARA
CALL LOAD_PARA
ALLOCATE(
+ NAMEP(NPM)
+ ,NPHASE(NBM),INDPH(NBM),IFLASH(NBM)
STOP
C
END
load_para.f
SUBROUTINE LOAD_PARA
USE MODULEPARA
NXM = 200
NYM = 200
NZM = 5
NPM = 4
NBM = NXM * NYM * NZM
END
modulecom.f
MODULE MODULECOM
CHARACTER*14,ALLOCATABLE ::
+ NAMEP(:)
CHARACTER*14
+ VERSION
INTEGER, ALLOCATABLE ::
+ NPHASE(:), INDPH(:), IFLASH(:)
+ ,NBLK(:,:), NBLKUP(:,:,:)
END MODULE MODULECOM
modulepara.f
MODULE MODULEPARA
INTEGER
+ NXM, NYM, NZM, NPM, NCM, NWM, NBWM, NS1M
+ ,NPRM, NPFM, NCTM, NHSM, NBM, NBM3, NBPM
+ ,NBPCM, NBNS1M, NCM2, NCMP1, NCPM2, NCMT
+ ,NBPCMT, NCWMT, NBCMT , NWBCM, NREG, NTAB
+ ,NZPM,NUMAUX,IC2,INQUA,INCON,INVEL,NOSWTM
+ ,NUMPRE,NUMOUT,NCVECT,NUMPVT,NHES,NPWM,NCWM
+ ,NCP1W,NST,NCCM, NBCM,IFLIP
END MODULE MODULEPARA
makefile
FFLAGS = -r8 -O3 -Bstatic
LFLAGS = -r8 -O3 -Bstatic
FMOD = modulecom.f modulepara.f
FSRCS = load_para.f main.f
FOBJM = $(FMOD:.f=.o)
FOBJS = $(FSRCS:.f=.o)
PROG = main.exe
FC = ifort
$(PROG): $(FOBJM) $(FOBJS)
$(FC) $(LFLAGS) -o $(PROG) $(FOBJM) $(FOBJS)
clean :
rm -f *.o main.exe
compilation errors
ifort -r8 -O3 -Bstatic -c -o modulecom.o modulecom.f
ifort -r8 -O3 -Bstatic -c -o modulepara.o modulepara.f
ifort -r8 -O3 -Bstatic -c -o load_para.o load_para.f
ifort -r8 -O3 -Bstatic -c -o main.o main.f
fortcom: Error: main.f, line 3: Error in opening the Library module file. [MODDULECOM]
USE MODDULECOM
fortcom: Error: main.f, line 4: Error in opening the Library module file. [MODDULEPARA]
USE MODDULEPARA
fortcom: Error: main.f, line 9: An allocate/deallocate object must have the ALLOCATABLE or POINTER attribute. [NAMEP]
+ NAMEP(NPM)
fortcom: Error: main.f, line 9: The rank of the allocate-shape-spec-list differs from the rank of the allocate-object. [NAMEP]
+ NAMEP(NPM)
fortcom: Error: main.f, line 10: An allocate/deallocate object must have the ALLOCATABLE or POINTER attribute. [NPHASE]
fortcom: Error: main.f, line 10: The rank of the allocate-shape-spec-list differs from the rank of the allocate-object. [NPHASE]
fortcom: Error: main.f, line 10: An allocate/deallocate object must have the ALLOCATABLE or POINTER attribute. [INDPH]
fortcom: Error: main.f, line 10: The rank of the allocate-shape-spec-list differs from the rank of the allocate-object. [INDPH]
fortcom: Error: main.f, line 10: An allocate/deallocate object must have the ALLOCATABLE or POINTER attribute. [IFLASH]
fortcom: Error: main.f, line 10: The rank of the allocate-shape-spec-list differs from the rank of the allocate-object. [IFLASH]
compilation aborted for main.f (code 1)
make: *** [main.o] Error 1
Please help me, thanks in advance.
James_UTA
amit-amritkar
Quoting - tim18
I tried to respond earlier. Admittedly, examples of Makefiles for .mod files are few and difficult to find by web search.
http://www.fesb.hr/~psarajce/Makefiles.html
You need at least a rule for making the .mod files and to show them in the dependencies list.
There are Makefiles in the ifort installation for building .mod files, e.g. for lapack95.
I don't know if you have figured this out yet or not but you have typos in your USE statement.
MODDULECOM -- MODULECOM etc.
I think if you fix this your code should compile.
TimP
amit-amritkar
Quoting - tim18
james_uta
Quoting - Amit
It works now with the correction of theerror, appreciate your great help.
james_uta
Quoting - tim18
Thanks Tim18 for your suggestion.
james_uta
Quoting - Amit
Hi Amit, could you please take a look at my another posted question as follows?
Home Forums Intel Fortran Compiler for Linux and Mac OS* X Help on mixed programming Fortran and C with intel fortran
I still can not figure it out, thanks in advance.
James
