Compiler Error
Michael8
Hello:
I am getting a compiler error, and was able to narrow it down to a test case.  The error is: The shapes of the array expressions do not conform.
I am using the 14.0.3.202 version of the compiler.  When I switch back to version 12.0.5.221, it compiles just fine.
Here is the sample code:
module TestMod
   implicit none
   private
   character (len = 100), dimension(5) :: charArr
contains
   character (len = 100) function GetCharArr()
      dimension :: GetCharArr(5)
      GetCharArr = charArr
   end function GetCharArr
end module TestMod
Can anyone explain to me why I'm getting this error message, or, if it is possibly a compiler issue?
Michael
It's a compiler bug. If you do it this way instead, it works:
      character(len=100),dimension(5) :: GetCharArr
I prefer this version as it keeps all the declaration in one place. For some reason the use of LEN= throws it off here. I will report this to the developers and will let you know of any progress. Thanks. Issue ID is DPD200362719.
Michael8
Thank you for the quick reply, and for the workaround.
I'll look forward to hearing about progress,
Michael
FortranFan
Michael,
In addition to Steve's suggestion, the following is also an option which provides both flexibility with respect to defining the function result as well as making it more readable:
   FUNCTION GetCharArr() RESULT(RetArr)
      !.. Function result
      CHARACTER(LEN = 100) :: RetArr(5)
      RetArr = charArr
   END FUNCTION GetCharArr
Also, consider adding the PURE attribute to FUNCTION subprograms as the compiler can help flag if the function has "side effects" beyond returning what it is supposed to.
I expect this bug to be fixed in Update 2.
Michael8
Thanks.  Just curious about the expected release date for Update 2?
Michael
Looks like early February.
