29640 Discussions
Compiler bug: value attribute not working
Lionel_Guez
Hello. Here is a test execution:
$ ifort --version
ifort (IFORT) 2021.9.0 20230302
Copyright (C) 1985-2023 Intel Corporation. All rights reserved.
$ cat test_value_attribute.f90
module func_value_attr_m
implicit none
type polyline
integer n_points
logical closed
real, allocatable:: points(:,
end type polyline
contains
logical function func_value_attr(p)
type(polyline), value:: p
p%points(:, 3) = [1., 2.]
func_value_attr = sum(p%points) >= 0.
end function func_value_attr
end module func_value_attr_m
program test_value_attribute
use func_value_attr_m, only: polyline, func_value_attr
implicit none
type(polyline) p
real points(2, 3)
points = 0.
p = polyline(n_points = 3, closed = .false., points = points)
print *, func_value_attr(p)
print *, "p%points = ", p%points
end program test_value_attribute
$ ifort test_value_attribute.f90
$ a.out
T
p%points = 0.0000000E+00 0.0000000E+00 0.0000000E+00 0.0000000E+00
1.000000 2.000000
This is a compiler bug. The variable "p" should not be modified by the call to the function, since the dummy argument has the value attribute.
Would you correct this bug?
jdelia
Hi Lionel_Guez :
Try with
$ ifx --version
ifx (IFX) 2024.0.2 20231213
$ ifx -error-limit 4 -e03 -fimf-arch-consistency=true -fimf-precision=high -finline-functions -fpp -ipo -mtune=generic -m64 -mavx -parallel-source-info=1 -qopenmp -qmkl -xHost -O2 -qopt-report=3 -parallel-source-info -std18 -fp-model consistent -WB -warn all -o testcase-0195-ifx.exe testcase-0195.f90 # (your source code)
$ $ testcase-0195-ifx.exe
T
Regards.
Jorge D'Elia
Arjen_Markus
You misunderstand the purpose of the value attribute: it does not protect against local changes of an argument. Instead it protect against the actual argument being changed, while you still can change it in a subprogram. If you want to ensure that the dummy argument cannot be changed, use the intent(in) attribute.
The "value" attribute is also useful if you interface with C: rather than passing by reference, it allows you to pass an argument by value.
Lionel_Guez
Thank you for your answer. I am sorry but I think you are wrong. Here is a quote from the  Fortran 2003 standard, § 12.4.1.2:
"If the dummy argument has the VALUE attribute it becomes associated with a definable anonymous data object whose initial value is that of the actual argument. Subsequent changes to the value or definition status of the dummy argument do not affect the actual argument."
Applied to my test program, the above specification says that a change to the value of the dummy argument "p" shall not affect the variable "p" in the main program.
Arjen_Markus
Oh, I misread your message. The actual argument is changed, where that should not happen. Hm.
jdelia
Hi Lionel_Guez :
Try with
$ ifx --version
T
Regards.
Jorge D'Elia
Lionel_Guez
Thanks. The most recent version I have access to is:
$ ifx --version
ifx (IFX) 2023.1.0 20230320
$ ifx test_value_attribute.f90
$ a.out
T
1.000000 2.000000
So the bug has been fixed somewhere between versions 2023.1.0 and 2024.0.2. That is good to know. Thanks again.
