29487 Discussions
Compiler bug when partially collapsing loops across incomplete arrays in ifort?
Bennett__Ed
I'm trying to port some code to OpenMP, and have encountered a problem. I've distilled out a minimal failing example below
      program test_collapse
      parameter(N1=8,N2=8,N3=4)
      real*8 R(N1,N2,N3)
c Set up an array
      do k=1,N3
      do j=1,N2
      do i=1,N1
      R(i,j,k)=rand(0)
      enddo
      enddo
      enddo
c Now do some work on it
!$omp parallel do collapse(2) schedule(dynamic) private(i)
      do k=N3-1,N3
      do j=1,N2
      do i=1,N1
      R(i,j,k)=R(i,j,k) + 1
      enddo
c Do some more work with this inner section of array in another loop here
c so collapse(3) won't work
      enddo
      enddo
c I would then do something else here to deal with the remainder of the array
!$omp end parallel do
c
      stop
      end
I'm compiling with
ifort -O0 -g -qopenmp -Wall -o ifort_test ifort_test.F
I see no reason this shouldn't work, and it works in gfortran, but with ifort (even with OMP_NUM_THREADS=1), it segfaults in the second loop. Changing the k loop to go from 1 to N3 allows the program to exit normally.
I encounter this on both a KNL machine and a Kaby Lake machine, using ifort 2017 and 2018.
Has anyone else encountered this or know how it can be worked around? Is Intel aware of this/planning to fix it in a future version?
Many thanks
Ed
jimdempseyatthecove
The collapse(2) should make the first two loop control variables (k, j) implicitly private, but should not affect the third loop control variable i, which conceivably could be (defaultly) shared (though compiler optimizations register-izing i may effectively make it private).
IOW add "private(i)" clause.
Jim Dempsey
Bennett__Ed
Thanks for your reply.
I've edited my initial post—previously it said private(ithird), which was a remnant of the old variable names that I edited for clarity in forum post version. Now it says private(i), which is equivalent to what was in my original code. I.e. even with the correct private clause, it still fails.
Conspicuously, if the collapse(2) directive is removed, or expanded to collapse(3), then the code also exits cleanly; it's only in the partially collapsed case that there's a problem. Similarly, if the outer loop starts at 1 rather than 3, then all works fine.
I've stepped through the assembly in GDB; the failing instruction is
movsd  (%rax),%xmm1
if that helps at all.
jimdempseyatthecove
Hopefully your posting (inclusive) of the edit to private(i) is sufficient to produce a failing reproducer at Intel.
The above instruction is a scalar move of a double precision variable. It is unusual for it to fail unless rax was not computed properly.
Jim Dempsey
