Compiler bug wrt C_F_STRPOINTER
Robert_van_Amerongen
New Contributor III
Again, there is a problem with this function:
C_F_STRPOINTER(CSTRPTR, FSTRPONTER, [NCHARS])
If I call it with nchars = 0, then I get a message:
ERROR: NCHARS is less than or equal to zero. [C_F_STRPOINTER]
To my opinion this not correct: the standard section 18.2.3.5 specifies: "NCHARS (optional) shall be an integer value with a nonnegative value". A value 0 thus is not excluded.
I have added a small example. I try to get the command line in a WinMain function
Robert
taehunkim
Thank you for your question.
​This issue has already been reported and will be resolved at next version (2025.0).
taehunkim
New Contributor III
