29657 Discussions
Compiler cannot load imf dispatching library
Alex_Schumann
With the provided rpms installed on Scientific Linux 6.2, the following compiler warning is thrown:
    hank@ftpi1:~ $ifort -o p8.out p8.for
    warning #13380: Compiler configuration problem encountered. Compiler cannot load imf dispatching library.
The environment is (in bash) set up like this:
   PATH="$PATH:/opt/intel/composer_xe_2011_sp1.9.293/bin/intel64"
   MANPATH="$MANPATH:/opt/intel/composer_xe_2011_sp1.9.293/man"
   export INTEL_LICENSE_FILE=${FLEXPORT}@${FLEXSERVER}
   source /opt/intel/composer_xe_2011_sp1.9.293/bin/compilervars.sh intel64
The same error appears whether using bash or csh.
Would you please show me an ls listing of/opt/intel/composer_xe_2011_sp1.9.293/bin ?
Lvcas_T_
Hello, Steve. I have the exact same problem, here's my list:
$ ls -l /opt/intel/composer_xe_2011_sp1.9.293/bin
total 196
-rwxr-xr-x. 1 root root  3719 Mar 21 16:22 compilervars_arch.csh
-rwxr-xr-x. 1 root root  4156 Mar 21 16:22 compilervars_arch.sh
-rwxr-xr-x. 1 root root  1002 Mar 21 16:22 compilervars.csh
-rwxr-xr-x. 1 root root   996 Mar 21 16:22 compilervars_global.csh
-rwxr-xr-x. 1 root root   939 Mar 21 16:22 compilervars_global.sh
-rwxr-xr-x. 1 root root   945 Mar 21 16:22 compilervars.sh
drwxr-xr-x. 2 root root  4096 Mar 21 16:22 en_US
drwxr-xr-x. 2 root root  4096 Mar 21 16:24 ia32
-rwxr-xr-x. 1 root root   380 Mar 21 16:24 idbvars.csh
-rwxr-xr-x. 1 root root   361 Mar 21 16:24 idbvars.sh
lrwxrwxrwx. 1 root root    18 Mar 21 16:22 ifortvars.csh -> ./compilervars.csh
lrwxrwxrwx. 1 root root    17 Mar 21 16:22 ifortvars.sh -> ./compilervars.sh
drwxr-xr-x. 2 root root  4096 Mar 21 16:24 intel64
drwxr-xr-x. 2 root root  4096 Mar 21 16:22 ja_JP
-rwxr-xr-x. 1 root root 58976 Feb 13  2012 loopprofileviewer.jar
drwxr-xr-x. 6 root root  4096 Mar 21 16:23 sourcechecker
-rwxr-xr-x. 1 root root 72169 Feb 14  2012 uninstall.sh
Thank you
TimP
It's more usual to put the compiler directories early in PATH and LD_LIBRARY_PATH rather than at the end, in accordance with the compilervars scripts.
The final xe_2011 update was released last October.
