29653 Discussions
Compiler error passing user-defined array to a subroutine
les_w_1
I'm having a Fortran 77 problem passing an allocated  user-defined Type array to a subroutine.  The subroutine compiles first without errors.  The calling program complains that the actual argument differs from the dummy argument.  The array has the same Type structure in both the sub and calling program. I'm using compiler v16.0.  I'd appreciate your help with this.
Calling program:
          type bounds
             real*8::fromth=0d0,toth=0d0,fromph=0d0,toph=0d0
          end type
          type(bounds),dimension(:),allocatable::elbounds
          integer num
          num=100
          allocate (elbounds(num))
          call sub(num,elbounds)
Subroutine:
          subroutine sub(num,elbounds)
          integer num
          type bounds
          end type
       type (bounds)::elbounds(num)
jimdempseyatthecove
Try this:
New module files:
           ! bounds_mod.f90
           module bounds_mod
             type bounds
             end type
           end module bounds_mod
           ! sub_interface.f90
           module sub_interface
             interface
               use bounds_mod
               integer num
             end subroutine sub
             end interface
           end module sub_interface
Calling program:
           use bounds_mod
           use sub_interface
           integer num
           num=100
Subroutine:
           use bounds_mod
           integer num
Jim Dempsey
It's not the same type by the language rules, it's a different type with the same name. Put the type declaration in a module and USE the module instead of redefining the type.
And by the way, this is Fortran 90 code, not Fortran 77.
mecej4
Two user-defined types are considered distinct if they have distinct definitions, even if they have components that match in type, order and size. Consider this example:
program xtypes
implicit none
type avec
     real x,y,z
end type
type bvec
     real x,y,z
end type
type(avec) :: u
type(bvec) :: v
u%x=10; u%y=12; u%z=15
v = u
write(*,'(3E12.3)')v%x,v%y,v%z
end program
The compiler says:
xtyp.f90(17): error #6197: An assignment of different structure types is invalid.
v = u
compilation aborted for xtyp.f90 (code 1)
One solution is to put the type definition in a module and USE that module instead of repeating the type definition in different subprograms. Another is to make the subroutine a contained subroutine, in which case the type is available by host association.
jimdempseyatthecove
Try this:
New module files:
           ! bounds_mod.f90
           module bounds_mod
             type bounds
             end type
           ! sub_interface.f90
             interface
               use bounds_mod
               integer num
             end subroutine sub
             end interface
Calling program:
           use bounds_mod
           use sub_interface
           integer num
           num=100
Subroutine:
           use bounds_mod
           integer num
Jim Dempsey
