29417 Discussions
Compiler for Intel 64 version 10.1.019 -- not found
Aaron_T_
I am looking for a specific version of your fortran compiler for windows. I need version 10.1.019 for Intel 64.
I need to use the Fortran compiler mentioned above, as it is the only compatible version to which I have access with my license file. Currently, the only build number for 10.1 available on your website is .034.
Thanks for your help
TimP
If you are able to log into the download site (https://registrationcenter.intel.com) try requesting a fresh copy of the license emailed to you.  If this doesn't enable you to install the version which you see available for download, please request help on the companion registration and licensing forum
http://software.intel.com/en-us/forums/intel-software-development-products-download-registration-licensing
I believe the versions you don't see there have been discontinued on account of incompatibility with various Windows and VS versions, so a license which was valid for a deleted 10.1 version might be extended to one which remains available.
Anonymous66
Valued Contributor I
Hello Aaron,
10.1 is no longer supported. Our policy is to support the last two major releases. For versions we no longer support, we only keep the most recent update on IRC.
Annalee
