Compiler option for Type structure
Intel_C_Intel
Using CVF6.6B
My question is about the sequence of compiling Type declarations
The following example module has two types, where the second type is depending on the first one.
module global1
TYPE ITEM
REAL COST
CHARACTER(LEN=30) SUPPLIER
CHARACTER(LEN=20) ITEM_NAME
END TYPE ITEM
TYPE PRODUCE
REAL MARKUP
TYPE(ITEM) FRUIT
END TYPE PRODUCE
end module global1
This compiles fine
Now when I change the sequence of the types in the following way
module global2
TYPE PRODUCE
REAL MARKUP
TYPE(ITEM) FRUIT
END TYPE PRODUCE
TYPE ITEM
REAL COST
END TYPE ITEM
end module global2
then I get the following error message
Error: This derived type name has not been declared. [ITEM]
TYPE(ITEM) FRUIT
This is because the Type ITEM is compiled after it is needed for the Type Produce
Is the a possibility (compiler option) to compile the second module without changing the sequence ???
The problem is, I have a source code with lots of Type declarations and they are all in the wrong order.
Thanks for any help
No such option - you'll have to correct the code.
Steve
