29640 Discussions
Compiler runs into problem compiling F77 code
Jason_Z_
I'm trying to compile Fortran 77 code (T-matrix code) on a Linux system using Intel Parallel Studio XE 2015 for Fortan and I have the recurring problem of too many errors.
I'm using: ifort ampld.new.f
and the errors that come up are:
ampld.new.f(1): error #5149: Illegal character in statement label field
This test result was calculated by the code in its
ampld.new.f(1): error #5118: First statement in file must not be continued
ampld.new.f(4): error #5149: Illegal character in statement label field
ICHOICE=1  NCHECK=1
ICHOICE=1  NCHECK=1
ICHOICE=1  NCHECK=1
ICHOICE=1  NCHECK=1
ICHOICE=1  NCHECK=1
ampld.new.f(5): error #5149: Illegal character in statement label field
RAT= .963711
RAT= .963711
RAT= .963711
ampld.new.f(5): error #5149: Illegal character in statement label field  [=]
RAT= .963711
ampld.new.f(6): error #5149: Illegal character in statement label field
PROLATE SPHEROIDS, A/B=   .5000000
ampld.new.f(7): error #5149: Illegal character in statement label field
LAM=  6.283185   MRR= .1500D+01   MRI= .2000D-01
ampld.new.f(7): error #5149: Illegal character in statement label field  [=]
ampld.new.f(4): error #5082: Syntax error, found IDENTIFIER 'NCHECK' when expecting one of: * ) :: , <END-OF-STATEMENT> ; . (/ + - : ] /) ' ** / // > .LT. < ...
ICHOICE=1  NCHECK=1
ampld.new.f(8): error #5149: Illegal character in statement label field
ACCURACY OF COMPUTATIONS DDELT =  .10D-02
ampld.new.f(9): error #5149: Illegal character in statement label field
EQUAL-SURFACE-AREA-SPHERE RADIUS= 10.0000
ampld.new.f(10): catastrophic error: Too many errors, exiting
compilation aborted for ampld.new.f (code 1)
I'm very new to Fortran and compiling code, so I have no idea where my problem arises.
Iv'e tried renaming the file to .f90 and the errors that come up for the .f90 compilation are:
ampld.new.f90(1): error #5082: Syntax error, found IDENTIFIER 'TEST' when expecting one of: ( % [ : . = =>
ampld.new.f90(2): error #5082: Syntax error, found IDENTIFIER 'SETTING' when expecting one of: ( % [ : . = =>
curent setting.
ampld.new.f90(4): error #5082: Syntax error, found IDENTIFIER 'NCHECK' when expecting one of: * ) :: , <END-OF-STATEMENT> ; . (/ + - : ] /) ' ** / // > .LT. < ...
ICHOICE=1  NCHECK=1
ampld.new.f90(6): error #5082: Syntax error, found IDENTIFIER 'SPHEROIDS' when expecting one of: ( % [ : . = =>
ampld.new.f90(6): error #5082: Syntax error, found '=' when expecting one of: ( * ) :: , <END-OF-STATEMENT> ; . % (/ + - [ : ] /) . ' ** / ...
ampld.new.f90(7): error #5082: Syntax error, found IDENTIFIER 'MRR' when expecting one of: * ) :: , <END-OF-STATEMENT> ; . (/ + - : ] /) ' ** / // > .LT. < ...
ampld.new.f90(8): error #5082: Syntax error, found IDENTIFIER 'OF' when expecting one of: ( % [ : . = =>
ampld.new.f90(9): error #5082: Syntax error, found '-' when expecting one of: ( % [ : . = =>
ampld.new.f90(9): error #5082: Syntax error, found IDENTIFIER 'RADIUS' when expecting one of: ( * ) :: , <END-OF-STATEMENT> ; . % (/ + - [ : ] /) . ' ** / ...
ampld.new.f90(10): error #5082: Syntax error, found IDENTIFIER 'THET' when expecting one of: * ) :: , <END-OF-STATEMENT> ; . (/ + - : ] /) ' ** / // > .LT. < ...
thet0= 56.00  thet= 65.00  phi0=114.00  phi=128.00  alpha=145.00  beta= 52.00
ampld.new.f90(11): error #5082: Syntax error, found IDENTIFIER 'MATRIX' when expecting one of: ( % [ : . = =>
AMPLITUDE MATRIX
ampld.new.f90(16): error #5082: Syntax error, found IDENTIFIER 'MATRIX' when expecting one of: ( % [ : . = =>
PHASE MATRIX
ampld.new.f90(17): error #5082: Syntax error, found '.' when expecting one of: BLOCK PROGRAM BLOCKDATA MODULE INTEGER REAL COMPLEX TYPE BYTE CHARACTER CLASS ...
  650.3172  -17.9846   10.0498  -12.7580
ampld.new.f90(18): error #5082: Syntax error, found '-' when expecting one of: <LABEL> <END-OF-STATEMENT> ; BLOCK PROGRAM BLOCKDATA MODULE INTEGER REAL COMPLEX ...
  -21.1462  631.6322 -127.3059   87.2144
ampld.new.f90(19): error #5082: Syntax error, found '.' when expecting one of: BLOCK PROGRAM BLOCKDATA MODULE INTEGER REAL COMPLEX TYPE BYTE CHARACTER CLASS ...
    6.8322  132.6131  635.2767  -34.7730
ampld.new.f90(20): error #5082: Syntax error, found '-' when expecting one of: <LABEL> <END-OF-STATEMENT> ; BLOCK PROGRAM BLOCKDATA MODULE INTEGER REAL COMPLEX ...
   -9.6629  -78.1229   51.4094  643.1738
ampld.new.f90(20): error #5082: Syntax error, found REAL_CONSTANT '51.4094' when expecting one of: * ) :: , <END-OF-STATEMENT> ; . (/ + - : ] /) ' ** / // > .LT. < ...
ampld.new.f90(21): error #5082: Syntax error, found IDENTIFIER 'MIN' when expecting one of: * ) :: , <END-OF-STATEMENT> ; . (/ + - : ] /) ' ** / // > .LT. < ...
 time =     .03 min
ampld.new.f90(23): error #5082: Syntax error, found IDENTIFIER 'CALCULATION' when expecting one of: ( % [ : . = =>
C   CALCULATION OF THE AMPLITUDE AND PHASE MATRICES FOR
ampld.new.f90(24): error #5082: Syntax error, found IDENTIFIER 'A' when expecting one of: ( % [ : . = =>
C   A PARTICLE WITH AN AXIALLY SYMMETRIC SHAPE
ampld.new.f90(26): error #5082: Syntax error, found IDENTIFIER 'THIS' when expecting one of: ( % [ : . = =>
C   This version of the code uses DOUBLE PRECISION variables,
ampld.new.f90(27): error #5082: Syntax error, found IDENTIFIER 'IS' when expecting one of: ( % [ : . = =>
C   is applicable to spheroids, finite circular cylinders,
ampld.new.f90(28): error #5082: Syntax error, found IDENTIFIER 'CHEBYSHEV' when expecting one of: ( % [ : . = =>
C   Chebyshev particles, and generalized Chebyshev particles
ampld.new.f90(28): error #5082: Syntax error, found IDENTIFIER 'GENERALIZED' when expecting one of: ( * ) :: , <END-OF-STATEMENT> ; . % (/ + - [ : ] /) . ** / // ...
ampld.new.f90(29): error #5082: Syntax error, found IDENTIFIER 'WATER' when expecting one of: ( * ) :: , <END-OF-STATEMENT> ; . % (/ + - [ : ] /) . ** / // ...
C   (distorted water drops), and must be used along with the
ampld.new.f90(29): error #5082: Syntax error, found IDENTIFIER 'MUST' when expecting one of: ( * ) :: , <END-OF-STATEMENT> ; . % (/ + - [ : ] /) . ** / // ...
ampld.new.f90(30): error #5082: Syntax error, found IDENTIFIER 'ACCOMPANYING' when expecting one of: ( % [ : . = =>
C   accompanying file ampld.par.f.
ampld.new.f90(32): error #5082: Syntax error, found IDENTIFIER 'LAST' when expecting one of: ( % [ : . = =>
C   Last update 08/06/2005
ampld.new.f90(34): error #5082: Syntax error, found IDENTIFIER 'THE' when expecting one of: ( % [ : . = =>
C   The code has been developed by Michael Mishchenko at the NASA
ampld.new.f90(35): error #5082: Syntax error, found IDENTIFIER 'GODDARD' when expecting one of: ( % [ : . = =>
C   Goddard Institute for Space Studies, New York.  The development
ampld.new.f90(37): catastrophic error: Too many errors, exiting
compilation aborted for ampld.new.f90 (code 1)
Please help me understand how I can troubleshoot this problem.
mecej4
If you downloaded the files from http://www.giss.nasa.gov/staff/mmishchenko/t_matrix.html, note that they have pre-pended the program output to ampld.new.f. Cut out those lines and put them into a separate file.
When you see the compiler output a large number of messages, such as one or more per line of code, that is a sign that the input source file has become mangled in some way, and it is useful to view it with a text editor.
Renaming the file with .f90 as the suffix, while well-intentioned, made things worse because, in addition to the program output being stitched on to the beginning of the file, lines beginning with 'C', which are comment lines in fixed format Fortran source, are not valid in free format Fortran source. The compiler considers files with suffixes .f and .for as fixed format and those with .f90 as free format.
In order to link the program, you will need some version of the NAG Fortran library compatible with the Fortran compiler that you use. You may consider using their "New LAPACK-based T-matrix codes" instead, which work fine with MKL without needing the NAG library, and produce correct output when run with Intel Fortran.
