Compiler selection on command line
Martin__Paul
새로운 기여자 I
1,122 조회수
Is there a way to tell Visual Studio on the command line which installed Fortran compiler to use? I have a scripted build which needs to use specific compiler versions for different source branches. I have looked into exporting settings in Visual Studio which can be loaded on the command line using /ResetSettings, but Intel Fortran compiler settings do not appear in the export list. Any ideas?
0 포인트
2 응답
Steven_L_Intel1
1,122 조회수
Do this. Call the ifortvars.bat script for the version you want, then use:
devenv /useenv
to invoke Visual Studio. This will use the environment variables already set up rather than what VS would normally use.
0 포인트
Martin__Paul
새로운 기여자 I
1,122 조회수
Thanks, that's exactly what I was looking for.
0 포인트
응답
